Code 33
Old Jul 9, 2014 | 12:02 PM
fordka's Avatar
fordka
How do you fix that one. So does that mean that it closes but something is sending too much power to do it.
Old Jul 9, 2014 | 02:25 PM
rla2005's Avatar
rla2005
Code 34 means the signal output from the EVP is above 0.67V when the EGR is closed. That can be caused by a faulty EGR valve (yes I know you stated you swapped in another, but it could be bad) or the EVP sensor is bad. If the EGR valve is used then you could have a build up of carbon on the pintle seat. That will keep it slight open which in turn triggers Code 34. Once again, it's a process of elimination and diagnosing the root cause.
Old Jul 9, 2014 | 02:30 PM
fordka's Avatar
fordka
Ahh ok got it. How do you clean the valves. Can that help
Old Jul 9, 2014 | 02:41 PM
fordka's Avatar
fordka
Ahh ok got it. How do you clean the valves. Can that help the problem
Old Jul 9, 2014 | 03:11 PM
rla2005's Avatar
rla2005
How to Clean an EGR Valve on a Ford F150 | eHow
Old Jul 9, 2014 | 07:35 PM
Eddiec1564's Avatar
Eddiec1564
When you replaced the EGR valve, did you use your old EVP sensor or one that came on on the"new" one?
There are different EVP sensors between years. I did have that code 34 but when I replaced the EVP for that year truck it went away.
Another issue that can cause code 34 after EGR valve replacement is the O ring for the EVP sensor to seal onto the EGR valve is missing or doubled up O rings installed. I forgot which post that someone found out about that here.
Old Jul 9, 2014 | 08:58 PM
fordka's Avatar
fordka
I left the original sensor top on. I can try the other one and see if it makes a difference. Unlesss new egr valves dont come with new sensors and this could be the original from my 87. It was a mechanic that replaced the valve. The o ring i know is there
johnnyfoodstamp
Oct 2, 2018 07:53 AM
timemachine455
Sep 1, 2018 06:57 PM
2oo1 4x4
1997 - 2003 F150
May 15, 2014 08:05 PM
Fordfr4x4
Mar 13, 2013 04:53 PM
russt
Oct 16, 2004 01:48 PM
