1998 F150 electrical issues, crazy
First time posting, coming here for help, I have a 98 f150 4x4, 4.6L 150k miles, during start up the blinker indicator lights on the dash illuminated and stayed on, when trying the blinkers they did not work, but if I shut the head lights off the blinkers do work and indicators respond normally. This is the same if I turn the fan blower on, blinkers don't work and indictors stay illuminated. Also I have found that the power windows, and 4wd no longer work. other functions work such as power mirror, radio etc. all fuses under the dash and under the hood are good, I tried switching some of the relays to see if that changed anything but with no success . took the kick panel off and inspected the grounds and all seem tight. It looks like the main battery ground is just to the body and there is one solid ground from the frame to the body under the cab. all seem tight and don't appear to be corroded. any ideas? truck starts and runs great.
rooster I'm having problems with my 99 ford expedition yesterday when driving down the road the o/d light started blinking and now when you put vehicle in reverse the starter engages also tried to put vehicle in neautral an crank nit and it started the vehicle just by pulling shift down
Please start your own thread in the most appropriate forum area instead of hijacking an unrelated one in the wrong section.
