Sponsored by: Real Truck
Annoying Shake
Old Jul 4, 2014 | 08:28 AM
MRivard2011's Avatar
MRivard2011
Annoying Shake
Hey y'all. My 2011 F350 is shaking like a wet dog, all the time, loaded with a trailer and empty. It's the whole truck, not just the front end or rear end. It'll shake a Dr Pepper flat in 10 mins. No one can figure out why. Maybe y'all can think of something.
Here's what we've done
New tires, balanced
Alignment
Replaced ball joints and sway bar
Replaced carrier bearing
Replaced passenger front hub that got mysteriously locked and henceforth destroyed.
Replaced all 4 shocks
Any ideas on where to look next?? Guess I should mention is 4x4 dually with 177,803 miles.
Old Jul 4, 2014 | 09:25 AM
Big-Foot's Avatar
Big-Foot
Have you tried De-Caff Dr. Pepper?
Okay - have you checked the U-Joints?
Does it shake more or less when you are on/off the throttle?
Welcome to FTE!
Old Jul 4, 2014 | 11:13 AM
artguys's Avatar
artguys
At what point did it start...can you tie it to any mods or repairs...at one point I specialized in vibrations and this would have been my first question to the customer before test driving it.
Old Jul 4, 2014 | 11:23 AM
r2millers's Avatar
r2millers
You say "all the time" but is that throughout all gears too?
Just thinking about the tranny torque converter lock up vibration.
When was the last time you serviced that tranny, esp with that mileage.
Old Jul 4, 2014 | 07:49 PM
fordman19762003's Avatar
fordman19762003
maybe you have an out of balance or bent drive shaft? Just to rule out an engine miss, does it shake while sitting?
Old Jul 4, 2014 | 09:03 PM
eberlestock's Avatar
eberlestock
My 2012 f250 xtracab does the same thing but I believe it is tire wear. I have 2 sets of tires and as soon as I rotate a new set the truck shakes. I had it re-aligned and have had the tires balanced multiple times. I thought maybe it was the rims but I have 2 sets and both do it! When I hook up a trailer it gets worse. Drives me nuts .
Old Jul 5, 2014 | 03:53 AM
MRivard2011
It started about a year ago, there was no real set point, we just noticed it one day.
We will check u-joints. It seems slightly worse at 60-65mph, then again at 75, or with a trailer on it, but it does it all the time. We've put 2 different sets on, all at different times, and kept up with rotations, never changes it. It doesn't do it sitting still.
Old Jul 5, 2014 | 08:59 AM
Field Truck's Avatar
Field Truck
Assuming truck is stock, I would go thru all steering/front suspension components with fine tooth comb. Pick a solid independent allignment shop that has verified truck history.
Like was suggested, drive shaft....maybe it threw a weight or ujoint is failing.
Then I would look at tranny.....
Good luck.
Mihylo33
Nov 2, 2014 08:45 AM
fast_fred
Jun 8, 2009 03:14 PM
ponch37300
Aug 20, 2008 08:32 PM
GregN
Oct 26, 2007 09:48 AM
wolfmanagh
Aug 31, 2006 09:16 PM
