Sponsored by: Real Truck
Rear Inner Seal leaking...
Old Jul 4, 2014 | 05:18 PM
nodesy's Avatar
nodesy
I followed a really nice writeup to do the rear brake shoes and rear seals on my dually. It is great to have a good resource for DIY (newbies) like me. However, my dilemma is that after putting everything back together and taking the truck down the road, I am leaking fluid past the newly installed seals. I don't know what could possibly be wrong, but it is a real pain. I think my breather is fine. Does anyone know if the same part number seal is used for single and dual rear wheel axles? I think I installed the seals correctly - they are snug up against the bearing.
Would really appreciate some help.
Thanks!
Old Jul 4, 2014 | 05:47 PM
powerstroker100's Avatar
powerstroker100
Thanks!
what did you torque the spanner nut to upon reassembly?
that torque procedure also seats the seal on the spindle
Old Jul 4, 2014 | 06:33 PM
nodesy's Avatar
nodesy
tightened 60 ft/lbs, then loosened 7 clicks.
Old Jul 5, 2014 | 10:41 AM
powerstroker100
sounds right, that is odd it is leaking
Ah so both axle seals are leaking. I'm not sure if there is a difference in dual and single rear wheel axle seals, but because both are leaking I would say the odds are somethings wrong with the seals, I know the ones I have used on my srw trucks is a national part number for about 27 bucks 370247A
applebaggins
Sep 24, 2017 11:57 AM
ajsanteiro
Nov 22, 2012 12:09 PM
Shade
Nov 15, 2011 01:26 PM
little_mule
Nov 4, 2009 07:33 PM
