FRONT ROTORS?
Old Jul 1, 2014 | 12:12 PM
lhud's Avatar
lhud
FRONT ROTORS?
I run Powerslot, cryod rotors with slots on the front. Has anyone tried turning these down to get more service out of them?
I know they are hardened, but thought I would ask.
Thanks guys,
Old Jul 1, 2014 | 12:39 PM
Bonanza35's Avatar
Bonanza35
How many miles are on them. They are not suppost to warp. I'd like to know so I don't buy them if they are that bad.
Old Jul 1, 2014 | 01:00 PM
Dan V's Avatar
Dan V
They are not hardened. I had a Powerslot that was a tad over a year old started to pulse. I chucked it up in a 15" engine lathe and faced .010 off each side. Like new now.
Old Jul 1, 2014 | 01:24 PM
lhud's Avatar
lhud
Bonanza35: 195,974 miles with Hawk pads; been pulsing for almost a year now. Most of my driving is open road.
DanV: I will try that. I thought these were super cooled hardened.
Thanks guys,
Old Jul 1, 2014 | 04:40 PM
KJNDIVER's Avatar
KJNDIVER
when i first got them i had gotten the wrong pads (ceramic), took a little longer but they eventually warped. had them faced and reinstalled with the correct pads and been running for about two years now trouble free. So to answer your question, yes they can be face just like a regular rotor.
Old Jul 1, 2014 | 04:55 PM
Pikachu's Avatar
Pikachu
No matter how had the rotor is, the tungsten carbide bit on a brake lathe is harder
Old Jul 1, 2014 | 07:33 PM
Bonanza35's Avatar
Bonanza35
Just wondered. Ihud, I have 18o,ooo on stock rotors and one went bad because I had a bad hub. I was looking for ART rotors but they can't be found I guess. Called them and e-mailed them and nothing works. I have been running motorcraft pads, so nothing but stock. Its hard to beat unless your running mountain roads a lot.
Old Jul 2, 2014 | 08:00 AM
Tugly's Avatar
Tugly
Slide pins are our bane. When you had the warping, did you check the slide pins on your calipers? Was the warping primarily on the inside?
Old Jul 2, 2014 | 09:43 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I had fought slide pins many times. I had greased them when I fist bought the truck 3 years ago. A few months ago I stated going through things looking for places to spend money. I found my right side pulling slightly when stopping. An inspection revealed a totally seized slide pin.
I ordered a set of reman loaded calipers and now I can, although don't recommend, stand on the brakes with no hands on the wheel and travel straight.
However, during smooth stops I notice a slight pulse in the pedal. No doubt a slightly warped rotor from excess heat.
Old Jul 2, 2014 | 10:24 AM
DieselCamper01's Avatar
DieselCamper01
I would not buy them again. I just replaced mine on Monday with stock rotors. I had one warp but now the layers of metal were starting to separate. Only about 40,000 miles on mine. Huge waste of money to buy cryoe'd Powerslots.
KJNDIVER
37
Aug 19, 2020 11:24 PM
00Dave
37
Oct 21, 2013 09:33 PM
BoulderLionX
Oct 26, 2011 06:49 PM
jdecker88
Aug 12, 2007 07:32 AM
Garff
May 10, 2006 09:39 AM
