Fuel tanks reading full
Old Jun 28, 2014 | 12:00 AM
Dflynn926's Avatar
Dflynn926
Okay, so I have been trying to search through and find something to directly help me. I have found a lot on the issue I am having, but the truck has me banging my head against the wall at this point and didn't know if someone could direct me more readily.
Now that I have ranted...
I am working on an 1988 F250 4wd 460 efi.
When I was driving the truck home after buying the rig I filled the front tank and put some in the rear. While driving the tank never left full and the rear then went to full and both haven't budged since.
Should I be looking a into the dual function reservoir, sending units, or what? also both tanks run the truck with no issues.
I have the bed off currently too.
Old Jun 28, 2014 | 07:26 AM
F350 1990's Avatar
F350 1990
I'd pull the sending units (floats), clean up the connections, add clean dielectric (as preventative maintenance) since you've got the bed off..........sooner or later they'll need it anyway.........then troubleshoot wiring, tank selector switch, etc.........
Old Jun 28, 2014 | 08:34 AM
DBGrif91's Avatar
DBGrif91
Seems to me that if this was a sending unit problem, you'd have issues with one tank reading being off, but not both at the same time (although to be fair, it is possible that both sending units could have the same problem at the same time).
If the gauge is pegged to the full point for both tanks and you know at least one of them is not full, it's most likely a gauge problem, or a wiring problem between the sending units and the gauge. Check the grounds for your instrument cluster (I'm sorry but I don't know where they are on a 1988 - Subford can tell you) and if that's all good, trace the wiring from the gauge to the sending units and check connections along the way.
Without having a wiring diagram, one thing I can tell you is that 1 common point for both gauges is going to be the fuel tank selector switch - it's possible that failed.
Old Jun 28, 2014 | 08:57 AM
choate's Avatar
choate
Man I need a truck like yours. Mine stays on E constantly.
Old Jun 28, 2014 | 09:21 AM
subford's Avatar
subford
The ground is behind the drivers headlight on the radiator support. But if the pumps are working the ground should be OK.
Old Jun 28, 2014 | 09:54 AM
Truck Guy99's Avatar
Truck Guy99
So what could be the cause of it reading full all the time? Mine has the same problem
Old Jun 28, 2014 | 11:18 AM
subford's Avatar
subford
Most of the time there is a buildup on the resistive element of the gauge sender making for an open circuit.
High resistance means the gauge reads full or an open pegs the gauge passed full as in the wiper not making contact with the resistive element or an open wire.
The photos below are from the 90's type gauge sender but 88 sender works the same way.
The resistive element:
The parts:
Old Jun 30, 2014 | 04:29 PM
Dflynn926's Avatar
Dflynn926
Awesome, I am going to try the sending units today... weather permitting.
If it is the tank selector how do I go about testing that?
Old Jun 30, 2014 | 05:25 PM
choate's Avatar
choate
U mean how to test if the tank is actually working and just the guage is not? If that is what you mean, I just got to a quiet place, flipped the switch to the tank that the guage was not working and put my hand on the tank to try to see if I could hear or feel the pump start to work
Old Jun 30, 2014 | 06:53 PM
F350 1990's Avatar
F350 1990
Before diving in that deeply, are you sure you don't have an OPEN in your circuit heading from the sending unit(s) up thru the selector switch up to the fuel gauge..........an OPEN in this circuit would give FULL readings from both tanks.......
Old Jul 8, 2014 | 10:53 AM
Dflynn926's Avatar
Dflynn926
I just want to thank you guys and all the helpful info.
I tested the sending units' pigtails by closing the circuit with a wire; both tanks then read empty. (little bit more redneck than with an actual ohmmeter, but works) I double checked by plugging in a new sending unit just into the pigtail and was able to move the gauge with moving the float by hand.
I swapped both sending units and both gauges are in working order.
Sadly I don't have magic tanks that stay full anymore... then again with the 460 I don't think they will ever really be full.
Thanks again
Old Jul 8, 2014 | 02:33 PM
choate's Avatar
choate
^ cool man so do you have to take off the bed and drop the tank to replace the sending unit or is this something you can do w/ the bed and tank still on? I probably need to do this too. Right now I put 5 gal in the rear and reset the trip odo to 0 and I know I can drive at least 65 miles or so lol. My front tank is kinda screwy too but it "seems" to work
Old Jul 9, 2014 | 10:08 AM
Dflynn926's Avatar
Dflynn926
I already had the bed off. I was painting the frame and the bottom of the bed with bed liner. It is going to be a work truck and is way to pretty to let rust away.
I think taking the bed off may be over-kill if you don't have another reason, but it made it the easiest fuel pumps I have ever replaced.
You will have to drop the tanks to do the front sending unit. if the rear is empty you may be able to get away with only dropping it slightly. but dropping them all the way out isn't crazy difficult.
towerwork
15
Mar 11, 2023 04:05 AM
KsCop
Mar 20, 2014 02:49 PM
imloggedin
Feb 29, 2008 12:47 PM
Gil Chesterton
Oct 25, 2005 10:09 AM
skeneguy
Mar 14, 2004 12:43 PM
