Fuel gauge sender
Old Mar 13, 2004 | 12:43 AM
skeneguy's Avatar
skeneguy
Fuel gauge sender
If a fuel gauge (1989) goes off the scale is it an open circuit or grounded? any ideas?
Thanks
Old Mar 13, 2004 | 03:59 PM
Manwith3fords's Avatar
Manwith3fords
Its caused by resistance. Is yours a midship tank? I had the same problem with mine. If you look at the wiring near the tank you will find a factory soldered connection, its probably "green" with corrsion like mine was. I cut it out, repaired it and now my gauge works great.
Old Mar 14, 2004 | 12:08 PM
skeneguy's Avatar
skeneguy
It was a new rear tank and sender unit put in, the needle pegs out as soon as the ignition is switched on. After looking at a wiring diagram, it looks like there is an inadvertant ground somewhere and the gauge ground it not being controlled through the sender rheostat. I thought maybe the tank has to be isolated from ground, but after checking another truck, that doesn't seem to be the case.
Old Mar 14, 2004 | 12:43 PM
Manwith3fords
I put a new sending unit and midship tank on mine last fall, it had the same problem even with the new sending unit. I got pis_ed off and traced the wiring from the tank to the dash and this is how I found the "green" spot in the wiring. Once I repaired that it worked great. I might have wasted $100 on a new sending unit for nothing so I kept the old one for a spare.
