She has just started to turn her lights off at the most IN opertune time...
12 at night when I am driving home, but they do come back on and will go off
again.....My question is..... switch or Steering collum....I replaced 9 inches of Black wire going to the passenger head light.. But that has not helped
I tried the LMC harness, what a total POS that thing is....
I replaced the headlight switch. That solved the problem for a few months. But now it's back.
Replace the dimmer switch, because when clicking from low to high beam, a common problem occurs, the headlights go out. Click back to low beam, the headlights come back on.
C0TZ-13A024-A .. Dimmer Switch (Motorcraft SW-24) is the same floor mounted switch for cars and trucks from the 1960's into the 1990's.
