Redhead Steering Gear Box Help!
The stickiest part will be getting a pitman arm off if you dont have a puller: Get a puller! Then, index the arm in the same direction on your new box. I think the arm can go on 4 ways; not only is it important to make sure it goes on the correct way, but it's pretty easy as well. Impact tools are nice to have for removing the pitman arm retaining nut, but I've done it several times with regular hand tools.
The rest of it is bolt in. The steering shaft may take a little persuasion to collapse so you can move it out of the way. Installation is the reverse of removal. There are some threads with "Tricks," about bleeding the steering system but I've never needed them. Just keep the fluid topped off and turn the wheels back and forth is all I've never needed to do, but if you DO have problems bleeding, the solutions range from jacking the front end up and turning the wheels to removing the box and tilting it to get air out.
For torques I couldn't find actual reference for my 79 so I went off the chart here.
For your steering pump, maybe you should check out some of the Saginaw pump replacement threads. I never looked back after doing mine and it was very simple. I think it's worth the effort of finding or building brackets to have something reliable.
My experience with Redhead boxes has been nothing but positive. Mine works, doesn't leak and has no slack. It was the final part of my steering system that had any slop.
edit : I read your profile it's a 302
You can find them in econoline vans with a 302 and some cars ..
I'm not sure if it's all there .. might be missing a spacer and some step bolts that go into the timing cover
http://www.ebay.com/itm/Ford-302-351-Saginaw-Power-Steering-Pump-Pulley-And-Bracket-Hotrod-Ratrod-/281369279267?pt=Motors_Car_Truck_Parts_Accessories&hash=item4182ea7b23&vxp=mtr
There is this option also
http://www.ebay.com/itm/Ford-289-302-351W-Saginaw-Power-Steering-Bracket-Billet-Aluminum-SBF-/121132552769?pt=Vintage_Car_Truck_Parts_Accessories&hash=item1c34101241&vxp=mtr
Also if we can get Numbers Dummy to list the part numbers for say a 77 econoline with a 302 you could look for availability in NOS .. I did find some of the missing parts I needed for mine that way ..
These pump have a TON of options involved with them. The size of the pressure port, the flow rate, the bypass pressure, the reservoir shape and number of mounting holes, if they had a remote reservoir or not...there are a TON of options.
For your application, any of the pumps should work, just be aware that there are some options out there. The most relevant to most of the swaps is the pressure port and weather it's metric or SAE. They swap back and forth, so if you get the wrong one from a bone yard, it's not a deal breaker; just head back and get a new port with a 1" (I think) wrench.
IF you get a junk yard unit, you can re-seal the whole thing in a day with a pretty cheap parts kit. It's a little messy, but easy and will save you from a leak later on.
302 re-introduced along with E100 in 1979. E100's and 302's were not offered between 1975/78 in Econolines.
1969/74 E100/300 240/300/302 have Power Assist P/S, use a different P/S pump.
Beginning in 1978: FoMoCo changed the P/S pump on everything (except Econolines and 1978/79 cars with Hydro-Boost that also use the Saginaw pump).
New pump has a plastic reservoir, is a different shape than the 1965/77 pumps that have a steel reservoir.
Plastic P/S reservoir pump: P/S pressure hose connects to the pump w/a qwik connect fitting. 1965/77 steel reservoir pump: P/S pressure hose threads onto pump.
