block cast number question
Old Jun 27, 2014 | 07:08 AM
7283-F250's Avatar
7283-F250
Basicly what the defferance between the 352 and a 501 cast on the front left of the blocks?
Is it FE vs FT?
Thank you
Old Jun 27, 2014 | 08:42 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
Most if not all of the "352" blocks were cast at DIF or CCC (dearborn iron foundry, cleveland casting center). The reverse "105" blocks were cast at the new at the time MCC (michigan casting center). The only FE blocks that were not cast at MCC were the 427 and 428. Those stayed at DIF. Some 428's at CCC later on.
Old Jun 27, 2014 | 12:50 PM
7283-F250's Avatar
7283-F250
Thank you.
So a guy looking for a 501 block is either looking for a numbers matching block or is misinformed of the ID number.
Old Jun 27, 2014 | 02:23 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
Well I guess you can call it a 501 block too. They are normally called reverse 105 blocks. It's just a foundry marking among others found on blocks. The casting numbers on those are sometimes on inside of the lifter valley. Example D4TE etc...... It can be either a FE or FT block depending on the original engine application. The FT used a larger/thicker distributor shaft. But there was a bushing Ford made to use a std size FE distributor in those blocks. Not too big a deal if you can locate one. Ford still sold those bushings until a few years ago. Other than that they FE/FT blocks are pretty much the same.
viol8r750
Jun 8, 2009 03:00 PM
1976rustbucket
Apr 25, 2008 11:57 AM
lifted77f250
Oct 27, 2007 09:10 PM
Ratsmoker
Apr 17, 2004 11:47 PM
relmer4
Jun 29, 2001 12:18 AM
