Battery not charging
Old Jun 25, 2014 | 05:27 PM
fordka's Avatar
fordka
Ok my 88 bronco hasnt been charging so i took the alternator off and had it tested. Turns out its good. So idk what else is wrong. Its a 302.
Old Jun 25, 2014 | 07:03 PM
Holmesuser01's Avatar
Holmesuser01
See if you are getting battery voltage on the big heavy wire at the alternator.
See if you are getting battery voltage on one of the small-diameter wires with the key ON without the engine running.
Old Jun 25, 2014 | 07:33 PM
Tedster9's Avatar
Tedster9
Save yourself a bunch of grief and just go ahead and replace all the battery and starter cables, body-block and block-frame straps, firewall strap, etc. They are over 25 years old at this point and corroded for sure. Maybe $20 or so. Break open all the connecting hardware on the alternator brackets where it mates to the block, that is the return path. High resistance in the charging system (and battery) will cause problems. Keep your battery on a low charge till things get sorted out, too.
Old Jun 25, 2014 | 09:14 PM
fordka's Avatar
fordka
Well battery cables have already been replaced and batter is only like 2 yrs old. But when i rev it up the battery light comes on when i rev it up and it goes away when i let off. But the volt gauge just stays where its at. Ill have to check out the wiring.
Old Jun 25, 2014 | 10:06 PM
F350 1990's Avatar
F350 1990
Unfortunately, the future aint what he used to be and 2 yr old batteries can be just as much of a pain as anything -- battery tech just hasn't advanced much and you can look at any battery
(most of the batteries in the US come from just two sources -----Deka (e.g NAPA) and Johnson Controls (Autozone, Walmart, Diehard, Advance Auto, Interstate, etc)
to see it's still pretty old, dated technology.........2-4 yrs of life at best
Old Jun 25, 2014 | 10:09 PM
fordka's Avatar
fordka
Haha ya i ended up figuring it out. While i was tracing the wires back i found i didnt have it connected to the starter silonoid. Oopsee
Fordclevor
1983 - 2012 Ranger & B-Series
Jul 30, 2016 08:30 PM
crestfallinman
33
Mar 1, 2012 09:54 AM
RangerPilot
Dec 5, 2007 12:25 PM
Smalltar
May 29, 2007 05:44 PM
BillyBob69
1997 - 2003 F150
Nov 2, 2006 02:00 PM
