Rear diff setup.
Old Jun 25, 2014 | 02:01 PM
wwgk1980's Avatar
wwgk1980
Rear diff setup.
1978 F-250 Dana rear end.
I am having problems with my rear diff, it looks like the pinion shaft nut has came loose and has been rubbing on the gear case(holds the crown gear). I think there has to be some sort of setup process to this, no to just tight the lock nut and call it a day?
Old Jun 25, 2014 | 03:47 PM
gatorfor88's Avatar
gatorfor88
There is a process to it. Some special tools required. Dial indicator to set backlash, have to press bearings on and off for shimming the pinion, Not rocket science but you do need to know what you are doing if you want it to last more than a year. Also if it has come loose and rubbing in the case there may be more problems that arent readily visible. I would suggest you bite the bullet and research a good shop to repair it. Most likely gonna co$t a $ub$tantial bit of ca$h.
Old Jun 25, 2014 | 03:48 PM
mikeo0o0o0's Avatar
mikeo0o0o0
You're correct, there is a detailed procedure to follow with setting the pinion depth and pinion bearing preload.
However, in this case I would tighten the pinion nut down and see what happens.
Remove the driveshaft, set the parking brake. Then get a ½" breaker bar and appropriate size socket and tighten the nut down. Don't get carried away though, I can't remember if the Dana uses shims or a crush sleeve to set the preload. If it's shims, how tight doesn't matter, if it's a crush sleeve you can tighten it too tight and change the preload.
Put the driveshaft back in and take it for a drive, see how it sounds. If it's been like that for a while, the pinion bearings could be trash or the pinion/ring gear could have odd wear patterns.
While you're there, think about changing the pinion seal.
Old Jun 25, 2014 | 04:38 PM
wwgk1980's Avatar
wwgk1980
Thanks mikeo0o0o0. I know I should be doing it 'the right way' but I just want to get it on the road. I am pretty sure it has shims and my Haynes manual says to torque it to 250-270 ft-lbs. Is it possible to check and see if things are working right by putting some lay out die on the pinion and roll the tires?
Old Jun 25, 2014 | 08:44 PM
mikeo0o0o0's Avatar
mikeo0o0o0
That would tell you if all the adjustments except backlash and pinion bearing preload are okay, but in this instance I would tighten the nut down and take it for a drive and see how it sounds. If its relatively quiet, you should be okay. Sound can tell you a lot about a rear end.
Old Jun 26, 2014 | 07:40 AM
wwgk1980's Avatar
wwgk1980
I tightened it up to about 270ft-lbs but then the wheels wouldn't spin so i back it off maybe a quarter turn (+/- a bit) until I could spin the wheels by hand so it felt like i thought it should. Going to drive it today, then jack the rear up again and give the wheels a spin tho see how it feels
Old Jun 26, 2014 | 08:10 AM
mikeo0o0o0's Avatar
mikeo0o0o0
How loose was the pinion nut?
I checked and the D60 does use shims for preload adjustment. Tightening it to spec shouldn't have made it lock up.
You might have bad pinion bearings.
Let me know how it goes.
Old Jun 26, 2014 | 08:24 AM
wwgk1980's Avatar
wwgk1980
Ok so that didn't go great. Started to shake at 40-50 km/h. I might try to back it off a little more and see where that gets me. I am just going to insure my other vehicle so i might try to take the time and do it properly now that there isn't a rush.
Old Jun 26, 2014 | 08:29 AM
wwgk1980's Avatar
wwgk1980
If you read the rest of this thread the 'just spin the nut back on' method didn't really work out. I had a look at the outer bearing and it looked fine so can i make the adjustments i would have to make without replacing the bearing? Therefore no have to take the rear end off?
Old Jun 26, 2014 | 08:56 AM
mikeo0o0o0's Avatar
mikeo0o0o0
It sounds like there are more problems than just a simple adjustment.
You need to pull the diff cover and inspect everything.
I have a sneaking suspicion that the ring and pinion are shot, along with the bearings.
If this is the case, its almost always cheaper and quicker to find a good used complete rear axle assy and just swap it out.
The bearings aren't that expensive but the labor is, and when you add the cost of a ring and pinion, it can get pricey real quick.
Old Jun 26, 2014 | 01:30 PM
wwgk1980's Avatar
wwgk1980
I had the cover off and the ring and pinion look really good except where the pinion crashed into the carrier. The front bearing looked to be in great shape as well. I might try to back it off again and take it for another drive just to see. I was trying to get it going to go camping for the long weekend this weekend but I dont see that happening so i am just going to let it sit for a week or so.
I do have a complete rear end but I am a little leery about swapping it. The brakes would have to be swapped and probably new seals all the way around.
Jeremy Kamutzki
Apr 30, 2014 06:33 PM
PM15106
1983 - 2012 Ranger & B-Series
Nov 21, 2009 09:00 PM
pikiluvi
Nov 4, 2006 01:53 PM
kopfenjager
Mar 2, 2005 12:42 AM
FordPerf300
Jun 2, 2003 07:28 PM
