1978 - 1996 Big Bronco
Front Hubs Getting Hot......
Old Jul 9, 2003 | 08:48 AM
VIBR8R's Avatar
VIBR8R
Unhappy Front Hubs Getting Hot......
I recently installed a set of Warn Premium Hubs on my 96 bronco xlt. I dont know if this is normal or not but after riding down the road for a while the hubs are scorching hot, i mean you can not even hold your hand on them. I packed grease in the wheel bearings and the hubs, and the hubs are in the free position. has anyone ever had this problem or is this normal?
Old Jul 9, 2003 | 01:22 PM
steve83's Avatar
steve83
The heat is either coming from the wheel bearings or the brakes. Not from the hub locks.
Old Jul 9, 2003 | 01:51 PM
HAWK28's Avatar
HAWK28
Maybe a "pinched" brake hose or "stuck" calipher?
HAWK
Old Jul 9, 2003 | 01:59 PM
mrwizard's Avatar
mrwizard
You're not supposed to pack the hubs with grease. Too much grease can cause them to bind. I doubt that's where the heat is coming from though.
Old Jul 9, 2003 | 02:02 PM
steve83's Avatar
steve83
It's OK to pack the "hubs" (the casting that the wheel bearings press into), but not the "hub locks".
Old Jul 9, 2003 | 02:05 PM
mrwizard's Avatar
mrwizard
Right. I assumed he meant the hub locks.
Old Jul 9, 2003 | 02:06 PM
78bigbronco's Avatar
78bigbronco
I had a brake that was sticking on my 78 but it only made the hubs slightly warm to the touch. But if you touched right at the base of where the wheel touched the hub then it would be hotter. Just my $0.02
Old Jul 9, 2003 | 02:12 PM
VIBR8R's Avatar
VIBR8R
I didn't exactly pack the hubs with grease. I just slightly smeared some on for the fact of the moving parts that came from the factory with no grease. but anywho is the heat something that i should be worried about? as for the stuck caliper i dont think that is what it is because the truck doesn't have a tendancy to pull one way or the other. However, i will look into it.
Old Jul 10, 2003 | 02:30 PM
mweeps's Avatar
mweeps
I had a friend who replaced the bearings on his 83 F100 and didn't get one seated right and the hub would get so hot it would glow orange until it finally seized up on him completely!!! BTW it was his first attempt at replacing them the first side was screwed up second side went on fine.
TchTchr
Feb 21, 2014 04:24 PM
ajonesnv
Sep 22, 2013 10:38 AM
MonsterTruck\m/
1966 - 1977 Early Broncos
Jul 18, 2011 09:59 PM
RhinoScores
Sep 23, 2006 09:29 PM
peppy
Offroad & 4x4
18
Feb 26, 2005 09:01 PM
