I keep seeing conversation on the 3 screw auto hubs, but never once have I found a thread in reference to the 5 screws auto hubs. I have 5 on my hubs. Is this not common or normal?
Mine were like that before one went bad and I swapped them out. They are actually preferable to have in my opinion, because if you plan to switch to manual hubs, you don't have to purchase the $60 install kit (Axle nuts I beleive) that you would need if you had the 3 screw variety.
ok i am gonna steal the thread for a minute....does anyone have any pics of the 3 screw hub after you remove the outside cap? i was working on a buiddies the other day but couldn't figure it out since I had never messed with any before! And the Haynes doesn't even have it in the books!
Fishy, Is this the type you are talking about?
They are similar to the 5 screw but usually require a convrsion kit to go to manuals. Just for the record there is a 6-screw type out there also.
Read the instructions on the new manual hubs. I think there is a big 'ol fat toothed washer on the autohubs that gets left out when installing manuals. Its been a while since a converted teh F250 and my Bronco has a completely different type of autohub than either of the 2 pictured here. I'm not familiar with anything from the factory of Fords newer than 1998.
The three bolts can be dirrectly convertd to manual hubs, or the five bolts need a convo kit. I had the 5 bolt auto hubs, but I switched to manual this weekend.
why do you want auto, they arent reliable...The past 4 or 5 times Ive been wheeling, they didnt work, but did at my house when I repacked them with grease, or even replaced the bearings and springs...
Originally posted by RawPower The three bolts can be dirrectly convertd to manual hubs, or the five bolts need a convo kit. I had the 5 bolt auto hubs, but I switched to manual this weekend.
Its my understanding that the 3-bolt require the conversion kit and the 5 and 6 bolt doesn't. As, far as grease, go by the hub instructions. You add grease to a Mile Marker when its new and the warranty is voided.
I didn't see anyone on this thread that said the want autohubs. Warn Premiums are the ticket or even regular Warn and Mile Marker.
Oh, sorry, I thought the original poster wanted to go from5 to 3 bolt auto hubs for some unknown reason.
My auto hubs were Ford, which are made by Warn for Ford, and they didnt work after I repacked them with grease.
On the Conversion kit I was saying that to go from 5(auto)-3 bolts (manual), you do need the kit.
Sorry for the lack of info to prevent any confusion...
No, I sure dont want to switch auto Hubs. I will being going to manual Warns. But thats a couple lines down my list. I was more just curious because I havent heard much about them.
Yea RLH, thats them. I had my right side hubs repacked due to a front end problem a few months ago, and the drivers side a couple of weeks ago for the same problem, different side.
Going for a new front differential before I worry about the hubs. Gotta loose that open diff.
