Please help - 911. Ford excursion issues.
Old Jul 22, 2014 | 10:14 PM
  #31
bbacon's Avatar
bbacon
I have a V-10 but learned the hard way that in the Texas heat you do not let the tank go below 1/4 tank or the fuel pump burns out. It is a doable job in the driveway. I did mine with about half a tank of gas in it. Used long rubber gloves. The fuel pump behaved very hinky for about a week before it gave out. Then I had the fender wall starter solenoid flake out which was causing starting and idleing problems. The truck would just quit at lights and start again once it cooled a bit. I bring up the fuel pump since you thought the tank had been tampered with. They do crap out and pump your tank are a very easy quick repair.
Good Luck.
Bowbowa
Jan 31, 2017 02:22 AM
Jimmy Crab
55
Aug 28, 2016 04:56 AM
Ted50426
19
Dec 2, 2013 10:31 PM
73strokin
Feb 19, 2008 04:19 AM
c-bolt
Mar 5, 2007 11:36 PM
