Ignition help
Old Jun 27, 2014 | 08:39 PM
Aesop's Avatar
Aesop
Originally Posted by 72CS
Got the voltmeter out and checked the ignition coil, distributor plugs and even to the tip of spark plug, all of which are getting 12v!
Dylan.
I don't understand "12 volts at tip of plug", shouldn't it be like 45,000 volts?
Old Jun 27, 2014 | 08:57 PM
351Cleveland C4's Avatar
351Cleveland C4
Will it light on starting fluid? If things are sparking and timed right then that means fuel isn't there.
How much have you cranked it? Did the float bowls get filled up? Idle screws adjusted properly?
Old Jun 27, 2014 | 11:49 PM
orich's Avatar
orich
After checking every think and still not starting you could try hot wiring the dizzy.
This will by pass your truck running circuit.
Place a small jumper wire from the +side of the battery straight to the +side of coil.
Then try starting it the ign key.
Now to kill the motor remove hot wire from battery.
The Solenoid should have 2 small wires one on each little terminal.
Those small terminal are marked with a (I)=ign & (S)starter these can be checked with a volt meter the (S)only gets voltage when ign. key turned to start is these get put on the wrong one it won't crank and could damage the solenoid.
Orich
Old Jun 28, 2014 | 04:02 PM
72CS's Avatar
72CS
- 351 Cleveland I will try to put gas straight down carb and try today.
- Orich I will check starter solenoid with voltmeter and try bypassing from battery to coil.
72CS's Avatar
72CS
Any possibility dizzy isn't set all the way down?
Old Jun 28, 2014 | 04:05 PM
351Cleveland C4
That's a possibility, but they seat fairly easily. If the lower shoulder is touching the block then it's seated.
Old Jun 28, 2014 | 09:25 PM
FECruzer69's Avatar
FECruzer69
72CS, unless someone converted your truck to electronic ignition, it will have points. An easy way to tell would be to look at the small wire(s) coming out of the side of the distributor housing. If there is only one wire coming out of the distributor and it is connected to the Negative (-) terminal of the coil, you have a points distributor. An electronic distributor, Ford or aftermarket with the possible exception of a GM style HEI dizzy, would have more than one wire coming out of it.
Old Aug 22, 2014 | 08:45 PM
72CS's Avatar
72CS
Thanks for all the help everyone! Once I replaced dizzy and buddy worked throttle while I turned ignition, she fired up, carb needs tuning.... Leak at the water pump, come to find out a bolt I forgot to put into new manifold was the culprit. Took water pump off to get bolt in and hose on. Did that, found a leak in the thermostat housing... Fixed that, now a leak in the water pump gasket, fixed that and manifold gaskets leaking. Now going to tear back into it and just do a cammy with it.
Thanks again for all who gave advice! It was greatly appreciated!
Old Aug 22, 2014 | 10:38 PM
orich's Avatar
orich
When new to engine wrenching work one finds many little thing that ya think don't matter until you add coolant or try starting it.
Then with a flood of leaks and vehicle won't start due to backfiring..
Is A Common problem.
Once repeated work is done one learns what not to do!g
Well glad you got it running so now you can pull it down and fix it right.
Now take your time.~~~ If your going add a cam to it don't get crazy with it or you'll have more headache trying to get to run right..
Orich
Old Aug 22, 2014 | 10:42 PM
351Cleveland C4
With cams, in these type of vehicles, less is more.
Old Oct 5, 2014 | 12:17 PM
69issofine's Avatar
69issofine
ign help
try disconnecting the wires to the coil and run 12v to the positive side hook a spark plug to the coil wire and scratch the negetive post on the coil to ground if no spark =bad coil.
Ben's 77
Sep 11, 2017 02:49 PM
FatherDonald74
1978 - 1996 Big Bronco
Jun 9, 2014 08:35 PM
mycam8u2
Mar 18, 2010 01:56 PM
Hellbore
Electrical Systems/Wiring
24
Jun 16, 2006 01:52 AM
mvassek
Nov 14, 2003 06:54 PM
