2007 4.2 plug change
Old Jun 23, 2014 | 11:20 PM
1969furd's Avatar
1969furd
well finally decided my truck needs ne plugs, she has 70k on her and she dont have the power like she used to.
sicne the back 2 cyl are kind of under the cowl, is here any easy way to change them out? any tools to make my life easier?
Old Jun 24, 2014 | 02:20 PM
1saxman's Avatar
1saxman
I don't know, but there are several other things that might cause it, like a dirty MAF, clogged air filter, bad catalytic converter or dirty fuel injection system. I would get a spray can of MAF cleaner, take the filter housing/MAF housing off and clean the MAF. Check the air filter at that time, as well as the air intake area (open the driver's door and look toward the front through the gap) in the fender for debris build-up. I have used a shop vac to blow the debris out of that area and clear the intake but don't do that with the intake tube attached - the crud might get into the filter housing. When you remove the intake tube from the throttle body, look for carbon build-up in the TB. Use TB cleaner spray accordingly if needed.
If you have not been using any kind of fuel treatment/cleaner, you may have gunk in the injector logs and build-up on the injectors, particularly if you use Ethanol-blended fuel most of the time. Additionally, you probably should change the fuel filter and check the fuel pump driver module above the spare tire. If it looks corroded, replace it.
Of course, it could simply be engine wear too, but hopefully that is not the case.
amaezing
1997 - 2003 F150
Jul 9, 2016 06:15 PM
hydro_37
Modular V10 (6.8l)
Nov 16, 2007 10:29 PM
jb8897
1983 - 2012 Ranger & B-Series
May 22, 2007 08:05 PM
SMarquez
Modular V10 (6.8l)
May 22, 2006 06:33 PM
rjousuf
1997 - 2003 F150
Dec 28, 2005 03:37 PM
