Duraspark 2 conversion carb
Old Jun 23, 2014 | 01:39 PM
Charles2703's Avatar
Charles2703
I'm not very familiar with the feedback carb setup and I've been trying to help a friend of mine do the conversion to get rid of that junk. What I'm not sure of is what carburetor does he need? We have the distributor, module, and a good harness. Any help would be greatly appreciated!
Old Jun 23, 2014 | 03:18 PM
Gary Lewis's Avatar
Gary Lewis
Depends entirely on what the engine is. We need to know the year, engine size, and preferably a pic of the current carb.
Old Jun 23, 2014 | 04:25 PM
Charles2703
It is an 86 f150 with a 4.9 straight 6. I don't have a picture but I will definitely try and get one!
Old Jun 23, 2014 | 04:57 PM
Charles2703
[IMG][/IMG]
Old Jun 23, 2014 | 05:02 PM
Gary Lewis's Avatar
Gary Lewis
IIRC the 86 did have the feedback carb. I used to think that those work fine w/the DS-II setup as even w/o the computer they just run slightly rich or lean - I forget which way it goes. But, one guy on here is having fits with his carb and it might be the feedback part.
What I'd do is try it with the existing carb and w/o the computer hooked to it, of course. If it runs well I'd leave it alone. But, if that isn't quite right then you would need the Carter w/o the feedback setup. I don't have a part number for that, but this thread is talking about that carb and that guy just ordered one so would have the info if you need it.
Oh yes, that is the feedback carb as you can easily see the connector. Good pic!
Old Jun 23, 2014 | 05:34 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
They run a little rich when there is no computer input.
"limp home" mode.
Old Jun 23, 2014 | 06:15 PM
Gary Lewis's Avatar
Gary Lewis
"limp home" mode.
That makes sense. Thanks, Jim.
But, I wouldn't buy a new carb until I tried it.
Old Jun 23, 2014 | 06:26 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Tully and a few others have bought those Ebay Repop Carter carbs.
I haven't heard any complaints about quality.
Old Jun 23, 2014 | 06:32 PM
Gary Lewis's Avatar
Gary Lewis
Yep. But someone ran the stock carb, played with a switch or somesuch on the solenoid, and concluded it didn't make much difference. Was that Ken Blythen?
Old Jun 23, 2014 | 07:35 PM
bill06447's Avatar
bill06447
I took my feedback carb apart on my 86 to clean it up and install a kit; there's nothing in it that would make it run richer or leaner than a standard carb. There's an anti-dieseling solenoid on the choke side, a sensor of some sort on the opposite side (appears to measure air flow, but the way it's mounted there's no way it adjusts anything) and a throttle position sensor under the fuel filter. The metering rod is adjustable along with the idle mixture but that's about it. I'd venture to guess that folks seem to think it runs rich when disconnected because without airflow and TPS inputs the EGR never opens and timing never advances since the computer will think it's always at idle. (truck runs fine btw) ~Bill
Bartsteltzer
38
Oct 26, 2016 04:36 AM
Superred2
175
May 1, 2012 08:27 PM
john165
Apr 9, 2012 07:29 PM
whisler
29
Mar 17, 2012 10:55 PM
Arkdriver
19
Oct 12, 2010 01:57 PM
