brake line brackets
Old Jun 23, 2014 | 08:07 AM
BossFan's Avatar
BossFan
Thanks redroad,
Hopefully I won't need to do much welding. The sheetmetal on my truck is in good shape. The bed was replaced with a newer-year, and just has one little hole in the wheelwell and the doors are cheapo reproduction pieces, but at least they are clean. It's the stuff underneath I'm most concerned about.
BTW - D&D was a great album! I keep hoping for another solo record (haven't been crazy about Working on a Dream or High Hopes. Nebraska is my all-time fave. The license plate on one of my cars is RSN2BLV.
Frank
Old Jun 23, 2014 | 08:22 AM
redroad's Avatar
redroad
Yeap Love the "Nebraska" album .. RSN2BLV .. Is your truck 2wd or 4 ?
Old Jun 23, 2014 | 11:00 AM
BossFan's Avatar
BossFan
4x4. I'll post some pics of her later
Old Jun 23, 2014 | 05:06 PM
BossFan's Avatar
BossFan
If I am going to try and drill out the rivets, which side do I mark with the punch, or does it even matter? And am I trying to drill all the way through, and if so, how big a drill-bit would you suggest? Here are what the rivets look like from both the outside and inside the frame:
Old Jun 23, 2014 | 05:13 PM
redroad's Avatar
redroad
do you have an angle grinder? Drilling them out for me anyways is by far the hardest .. If you can borrow or if you have a 5" angle grinder it will make things easier .. Safety glasses on grind the head odd and drive it out with a flat tip punch .. Besides you'll need a 5" angle grinder to go with your new welder ..
Old Jun 23, 2014 | 05:27 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Yeah, an angle grinder is easiest way. Grind the head flush and then use a punch to drive the rivet out. If you grind the head off, it doesn't matter which side you work on.
If you're going to drill the rivet out, work on the side that is smaller or flatter. The drill bit needs to be the same OD as the rivet's shank or slightly smaller.
Old Jun 23, 2014 | 06:18 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Yes that rusty bracket on the underside of the frame is a bump stop for the factory blocks.
Your springs look like they have factory overloads. With overload springs that little spacer is suppose to be there. Do you have some stop brackets in line with the top leafs when the truck suspension is compressed on the outside of the frame, you should.
Drilling a rivet is painful IMO, get or rent a 4" with a thin cutting blade and make alot of passes, or use a man sized 7" grinder (w/lots of sparks) and go to town on the head of that sucker.
Safety glasses and no open fuel tanks is something to make sure of. If the sparks bother you around the fuel tank, wet down a old blanket and put it on the fuel tank. But gas fumes are still some thing to be aware of.
Old Jun 23, 2014 | 06:24 PM
77&79F250's Avatar
77&79F250
Here is a shot of some over loads and the frame side brackets. I believe these are aftermarket over load brackets...? Nice frame crack huh?
Old Jun 23, 2014 | 06:46 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Holy Crap!!
Old Jun 23, 2014 | 07:56 PM
77&79F250's Avatar
77&79F250
It had a monster size flat bed on it when I got it and it had probably hauled a couple of 1000 to 1200 lb round hales of hay 2 or 3 at a time more than once.
The 3rd pic is for folks that slam flat beds.....
HJ over, back to brake line bracket and rusty rivet removal.
Old Jun 23, 2014 | 08:15 PM
BossFan's Avatar
BossFan
Yes, my truck does have brackets like that. I remember replacing the pads last summer. I was going to remove these, clean them up, and repaint them.
Old Jun 23, 2014 | 08:17 PM
BossFan's Avatar
BossFan
I was going to drop the tank anyway, so maybe that's when I start the grinding. I just can't tell which side of the rivet is the head, or does it not matter?
Old Jun 23, 2014 | 08:26 PM
  #28
mikeo0o0o0's Avatar
mikeo0o0o0
Nope, doesn't really matter.
  #29
77&79F250's Avatar
77&79F250
Rivet head is round and usually on the outside?? Looks like you have 4 springs for overloads, interesting. I also notice they are like the rear shock mount brackets, they trap water...
The rear shock mounts have a small drain notch on the frame side that road grim fills and clogs up quickly. Maybe a small notch on the inside frame contact side of the bracket, once removed would help?
Old Jun 24, 2014 | 07:26 AM
  #30
BossFan's Avatar
BossFan
Thanks. I don't know the history of the truck, but would those four overload springs come that way from the factory? Should I remove them? I never load the bed with anything, although I would like to eventually be able to pull an enclosed motorcyle trailer with this truck, so maybe best to leave them alone. How do you know if it's time to replace the springs, and are they hard to remove even to just clean them up? Are they under tension like the front coil springs in a car, or are they more like the rear coils springs? This truck stuff is all new to me.
Thanks for the tip on cutting a notch. That makes sense. You can see how the inside of that bracket has rust from water sitting in it.
