no start after all this....
Old Jun 21, 2014 | 12:56 PM
BigSteve74's Avatar
BigSteve74
Unhappy no start after all this....
05 F250 FX4, 119000 miles,
was running fine with the exception of puking every now and then... wanted to do a coolant flush, and checked the oil temp/coolant split - found it at 26 degrees, so figured I would do the oil cooler as well. Ended up getting a new SCT fitting, stand pipes, dummy plugs, EGR delete, and oil cooler.
Took it apart, replaced all the parts, (did have to pull the HP oil rails out to get the Stand pipes out) now it turns over and nothing...
FICM Voltage is 48.5
Vehicle voltage is 12.3
IPC is 1285
IPR is 85%
I think those acronyms are correct...
any ideas before I start to take it back apart?
Thanks,
Steve
Old Jun 21, 2014 | 01:24 PM
mustang_309's Avatar
mustang_309
IPC is 1285
IPR is 85%
Thanks,
Steve
Is that ICP actual or desired? What is the ICPV's KOEO? And how much cranking have you done trying to get it started? It can take a fair amount of cranking after that kind of work. Have you checked to make sure the FICM connectors are fully seated as evidenced by the audible click when the connector seats?
Old Jun 21, 2014 | 01:30 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Trash on the IPR screen or unseated FICM connectors is my initial thoughts.
Josh
Old Jun 21, 2014 | 08:22 PM
BLADE35's Avatar
BLADE35
Looks Like they got you off to a Good start^^
Are You
Cranking @ 150 RPM+??
And Show FPW other then 0??
Looks Like a HPO Problem But still to be more verified as mentioned ABOVE^^Post
Likely Jacked up the IPR Valve this whole Time (IF!! I take it you started with Oil Cooler and EGR deleate and re assemble to a No start
ORder of event would help Bud as Much Possible detail
Old Jun 21, 2014 | 08:31 PM
BLADE35's Avatar
BLADE35
No worries though you will get it
You will Know about the IPR as soon as you pull it and check the screen BUT Get THERE^^^ sensor/valve Numbers Charge your Battertys and stuff Check All Wires Before Teardown
Maybe you did do some IDK you probably did
Old Aug 4, 2014 | 01:27 PM
BigSteve74's Avatar
BigSteve74
It has been a while but, I was scared to keep cranking it, finally after what seemed like forever, it gave a hint of wanting to start. Then after one more long cranking cycle it fired up
Thanks for the pointers!
think I will have to pull it back apart again to do the head gaskets and studs....
tunaguy
Jan 28, 2016 11:01 PM
mrmower
Nov 14, 2012 09:13 PM
Special Ed
Apr 7, 2012 08:52 PM
eliwho
Feb 23, 2012 06:17 PM
plindsay105
Aug 16, 2010 08:37 AM
