EOT/ECT highest ever
Old Jun 22, 2014 | 10:08 AM
  #31
raptor131's Avatar
raptor131
Originally Posted by BjornF16
I'll program those in.
Yesterday on a road trip to Paris (not pulling anything), I had these fairly stable numbers at OAT = 90F:
EOT = 202F
ECT = 196F
TFT = 160F
When we hit stop and go traffic, max speeds approx 45-50 mph, they jumped to:
EOT = 210F
ECT = 204F
TFT = 180F
Normal?
btw, idiot gauges didn't move (I just recently got the ScanGauge II and I'm a little shocked at how much temps move without idiot gauge moving).
Looks like it, there is a great thread on recommended temps and readings in tech folder here https://www.ford-trucks.com/forums/9...-pressure.html
Old Jun 23, 2014 | 08:56 AM
  #32
KDAVID1's Avatar
KDAVID1
was 81 this morning and eot was 203 and ect was 198
Old Jun 23, 2014 | 06:58 PM
  #33
KDAVID1's Avatar
KDAVID1
So my fan speed stays pretty low even when I get on it when warmed up. It does ramp up after fully warmed up and accelerating to 45mph then starts going down one past 45 and also goes up when parked. Basically stays about 1300 rpm below engine rpm at highway speed when warmed and parked is within 300 or so rpm of engine rpm when warming up. I guess thats how its supposed to work.
Old Jun 23, 2014 | 07:54 PM
  #34
joejackF250's Avatar
joejackF250
Having the same issue. Cruising down the highway on my way to work in the morning at around 75 degrees EOT and ECT are in the 190s range. However coming home from work in the afternoon at 95 degrees the oil temp sometimes gets up to 205+ and up to 212 plus while idling. I do have the A/C on as well
Old Jun 23, 2014 | 08:10 PM
  #35
KDAVID1's Avatar
KDAVID1
Im never in traffic too long myself but when I'm stopped or idling my temps drop instead of going up. My fan seems to be working correctly (I guess) like bismic said wish I had a good way to check flow and pump without digging in but like others this may be the normal for my truck---I just want to know for sure.
Old Jun 24, 2014 | 06:45 PM
  #36
KDAVID1's Avatar
KDAVID1
I have decided my system is fine. Today outside temp was 85 and ect stayed in the 192 to 196 range. Not going to sweat it. I am in the planning for doing some things--BD water pump, egr delete, dummy plugs/stand pipes, stc, new oil cooler (since ill have access) nothing wrong with the truck just stuff to have fun with.
Old Jun 24, 2014 | 07:17 PM
  #37
jswartz84's Avatar
jswartz84
Just a heads up, there have been quite a few guys on here change their OC just because they were in the area. Afterward, their temp spreads seem to be further apart then before. If your spread is good, I'd leave it alone.
Old Jun 24, 2014 | 07:23 PM
  #38
jsm180's Avatar
jsm180
Mine runs 190-192 CT and 199-203 OT @ 70-75 mph regardless of OAT, did 200 miles the other day OAT was 90-95 the whole trip. If you haven't changed the thermostat, might be a good time.
Old Jun 24, 2014 | 07:27 PM
  #39
KDAVID1's Avatar
KDAVID1
Good point but with egr delete the spread wont matter as much will it?
Old Jun 24, 2014 | 07:45 PM
  #40
jswartz84's Avatar
jswartz84
No, you just don't want the EOT to hit 253°
Old Jun 24, 2014 | 07:55 PM
  #41
KDAVID1's Avatar
KDAVID1
That's what I was thinking. Will weigh it out when I'm ready to get started I suppose.
BGLeRoy
Apr 16, 2019 09:58 PM
khump
6.7L Power Stroke Diesel
Apr 21, 2016 06:23 PM
SHOOTER22250
May 15, 2013 06:53 PM
ROBBINthaHOOD
Mar 17, 2013 12:09 PM
kbnconstruction
Nov 1, 2009 09:16 AM
