Alternator swap
Old Jun 20, 2014 | 08:14 AM
fordka's Avatar
fordka
Alternator swap
Anyone know if a alternator off a 87 f150 4.9 is the same as 5.0 on a 88 bronco.
Old Jun 20, 2014 | 11:32 AM
timbersteel's Avatar
timbersteel
Different mounting, won't work.
Old Jun 20, 2014 | 11:35 AM
fordka's Avatar
fordka
Are you sure i just compared the 2 they look the same
Old Jun 20, 2014 | 12:27 PM
rla2005's Avatar
rla2005
Both are probably the same fire-prone 2G alternator. Since you have both in your hands measure them.....but they should be the same.
Old Jun 20, 2014 | 01:22 PM
Evan_P's Avatar
Evan_P
I wouldn't use either. 3G or nothing. I don't want my truck burning to the ground.
Old Jun 20, 2014 | 02:28 PM
timbersteel
They do look the same. But I had a spare for my '92 300, and it would not physically mount in the bracket for my '92 302.
Unless Ford had a quirk for that year, I know either won't swap.
Old Jun 20, 2014 | 02:39 PM
fordka's Avatar
fordka
I still have yet to get the old one off. The bottom bolt thats long is being a pita. The plugs i know are the same
Old Jun 20, 2014 | 02:51 PM
timbersteel
You can also check O'Reilly s website or AutoZone or advance auto web site and check to see if there are 2 different part numbers.
Old Jun 20, 2014 | 04:08 PM
fordka's Avatar
fordka
I tried looking up part numbers but they had like 20 different alternators for each. If it doesnt work anybody know a good place to buy new ones. I refuse to buy autozone electronics they dont last worth of crap. I think napa would be best.
Old Jun 20, 2014 | 04:30 PM
rla2005's Avatar
rla2005
If you have to get a new one seriously consider upgrading to a 3G. At the very least you should get a new connector pigtail for that fire prone 2G. Ford advises to always replace the connector every time it is disconnected.
Good reading in this thread: https://www.ford-trucks.com/forums/1...ator-fire.html
Old Jun 20, 2014 | 07:44 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The 4.9 takes a 8.25" C-C mounting.
The Windsors use 7" C-C ears.
If you go with a 3G you want one from a 3.8 V6 Taurus/Sable '92-'95 or so.
Old Jun 20, 2014 | 08:07 PM
rla2005's Avatar
rla2005
There you go!
Thanks
Old Jun 20, 2014 | 09:02 PM
F350 1990's Avatar
F350 1990
I'm with you on this automoan electronics problem --NAPA has them beat hands down on quality --- I won't use automoan parts ever again.
Old Jun 20, 2014 | 09:53 PM
fordka's Avatar
fordka
Id prolly do the 3g if i wasnt selling the truck in a few months. Im not apposed to it but what all is needed to do the swap.
Old Jun 20, 2014 | 10:09 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
A charge cable and 175A megafuse + holder.
30" 4Ga or larger for my 460.
Not sure the length for an I-6
You can reuse your regulator plug if you have a ring terminal for the yellow/white wire and an insulated female spade connector for the white/black stator wire.
85F350IDI
Apr 20, 2014 01:32 AM
centquinze
Nov 25, 2012 06:31 PM
89_Brnko2!!
Bronco II
Jan 7, 2010 12:23 AM
