Sponsored by: Real Truck
alternator swap
Old Nov 24, 2012 | 08:20 AM
centquinze's Avatar
centquinze
alternator swap
Hi guys, just replaced alternator(bought rebuilt) on my f250*(2006)superduty...when i unplug battery after engine is started it stalls....cannot run on alternator alone....any suggestions
Old Nov 24, 2012 | 10:25 AM
jh818's Avatar
jh818
Get the alternator bench tested.
Old Nov 24, 2012 | 11:23 AM
centquinze's Avatar
centquinze
Alternator bench...core??
Old Nov 24, 2012 | 11:28 AM
jh818's Avatar
jh818
Take your alternator to any chain auto parts store and they will hook it up to their machine and test the output for you for free.
Old Nov 24, 2012 | 11:45 AM
centquinze's Avatar
centquinze
Thanks....and relays or fuses thatcould be making the alternator not charge or send current.??
Old Nov 24, 2012 | 02:57 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
You should never disconnect the battery on a modern vehicle to check the alternator integrity.
Also, the "I" circuit on the alternator needs battery voltage to switch the voltage regulator on or "excite" the charging process. Disconnect the battery and you no longer have voltage on the "I" circuit therefore no charging.
Josh
Old Nov 24, 2012 | 03:19 PM
centquinze's Avatar
centquinze
Thanks.... No more old scool
Old Nov 25, 2012 | 06:31 PM
centquinze's Avatar
centquinze
New rebuilt alternator was defective....
josh.lanford
Electrical Systems/Wiring
Mar 8, 2011 06:09 PM
keating8070
Sep 7, 2010 05:43 PM
Skier041
Apr 5, 2008 11:11 AM
Ron Lawson
Aug 21, 1999 08:47 PM
