headlight switch
Old Jun 19, 2014 | 09:23 PM
okiewelder's Avatar
okiewelder
headlight switch
Ok lm putting a new wiring harness in my uni. I would like to use a different headlight switch. Is there anyone that has used a different one that they would recomend that fits in the origional hole and looks good?
Thanks,
Steven
Old Jun 22, 2014 | 12:37 AM
w5nra's Avatar
w5nra
I don't have an answer to your question, just wondering why you want to use a different one? You can get one for your truck and they are fairly inexpensive.
w5nra
Old Jun 22, 2014 | 09:53 AM
okiewelder's Avatar
okiewelder
switch
Im out on the road and cannt actually look at my truck. Doesnt the factory switch have fuses in it? Im just trying to upgrade it as l put it togeather. Maybe lm just over thinking it as usual?
Old Jun 22, 2014 | 10:38 AM
Tedster9's Avatar
Tedster9
Integral circuit breaker, not a fuse.
Sent from my iPhone using IB AutoGroup
Old Jun 22, 2014 | 10:46 AM
w5nra's Avatar
w5nra
I have seen some pictures of the headlight switch connector having fuses but honestly don't remember what my connector looked like. I do know that with the old harness off that the headlight switch just has spade terminals to plug your wires.
Terry
Old Jun 25, 2014 | 11:03 AM
CTom's Avatar
CTom
The head light switch plugs directly into the fuse block.............Most parts stores have them for around $20
Old Jun 25, 2014 | 11:32 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1961 F100/750 & 1962/64 F100/600: The fuse panel (junction block) plugs into the headlamp switch. 1961's use a different switch than 1962/64's. See parts catalog pic for 1964 example.
1965/66 F100/600's use a different headlamp switch, have a separate fuse panel located on the inside of the firewall adjacent to the steering column.
Old Jun 25, 2014 | 01:07 PM
w5nra's Avatar
w5nra
I was fairly certain that my 65 did not have fuses on it and thought I had seen some with fuses. I did not realize that the attached fuses was the fuse panel.. they've gotten a little bigger! haha
okiewelder didn't say what year he was working on.
Old Jun 25, 2014 | 08:36 PM
NumberDummy
OP didn't need to say what year...says he's putting a new wiring harness in his Uni .. which would be a 1961/63 F100/250 2WD
C1DF-11654-A .. Head Lamp Switch = 1960/61 Falcon/Comet / 1961 F100/750.
C2DZ-11654-A .. Head Lamp Switch (Motorcraft SW-303) = 1962/63 Falcon/Comet / 1962/64 F100/600.
D3ZZ-11654-A (replaced C5DZ-11654-A - C5TZ-11654-A, B & C - C8UZ-11654-A - D1ZZ-11654-A) .. Headlamp Switch Kit (Motorcraft SW-1245).
1965/66 Mustang / 1965/70 Falcon/Comet / 1965/72 F100/600 / 1969/75 Econoline / 1971/72 Mustang/Cougar / 1973/75 F100/350 / 1976 E/F100/350 before serial number C25,001.
Old Jun 26, 2014 | 04:36 PM
w5nra's Avatar
w5nra
LOL, for us non-observant folk he did!! haha
I am not as well versed, I barely know enough to be dangerous about my 65! Although, I am picking up bits and pieces by those like you ND and others that know the ins and outs.
Terry
Jose A.
Aerostar
Nov 24, 2015 10:40 AM
Hutch17
16
Oct 1, 2013 04:11 AM
tucn26s
Apr 11, 2010 10:50 PM
Woodsman_30350
13
Feb 28, 2009 07:43 AM
