need power steering help!!
Old Jun 19, 2014 | 06:57 PM
goosehunta's Avatar
goosehunta
i lost power steering today!! fluid is full, no leaks and I can take the top off the fluid resavor and see the fluid moving in there. when I done my engine job I also replaced the steering box with a red head box and also replaced the pump with a reman unit from rockauto. all this was done about 6000 miles ago. could the pump be bad already? or could it be something with the brake booster. I don't know a lot about hydro boost systems.
any ideas?
thanks in advance
Old Jun 19, 2014 | 08:11 PM
steelhead2's Avatar
steelhead2
How do your brakes feel? If the pump was bad youd feel it in the pedal.
Old Jun 19, 2014 | 08:39 PM
goosehunta's Avatar
goosehunta
don't have any stopping power. more pedal traval than normal
Old Jun 19, 2014 | 11:54 PM
Yahiko's Avatar
Yahiko
Sounds like you may have a bad pump.
Likely what you seeing in the bottle is the
pump pressure relief valve venting.
When you installed it did you
place the system under a vacuum to help
remove any trapped air in the pump before starting?
Sean
Old Jun 20, 2014 | 08:34 AM
goosehunta's Avatar
goosehunta
I did not put under vac. But I jacked the front end up and rotated stop to stop a lot. I mean a lot too. Also pressed brake several time all while checking level to make sure it didn't start sucking air. Had a helper watching fluid level. Steering and brakes have been no problem until yesterday. Now I only have power when running down road. The pump I put on was a A1 cardone reman unit. Only lasted 6000 miles. Is there a good pump to go with. Thinking about reman motorcraft. Really can't replace every oil change lol.
Sent from my iPhone using IB AutoGroup
Old Jun 20, 2014 | 10:21 AM
Yahiko's Avatar
Yahiko
You may want to give the people at Read Head a call
and pick there brains on what may of gone wrong
and best replacement to get.
Sean
Old Jun 20, 2014 | 11:28 AM
goosehunta's Avatar
goosehunta
I may give them a call when I get a few minutes. I do love my redhead steering box. I am hoping it's just a bad reman unit and there is no other problems.
Mike Mccord
Mar 13, 2017 11:30 AM
titanminator
16
Mar 21, 2012 03:36 AM
frostysdriver
Jan 11, 2011 10:49 PM
Mathematicus
Mar 12, 2010 04:49 PM
zogy
Jan 22, 2004 04:49 PM
