NEED HELP ASAP!!
Old Jun 18, 2014 | 12:47 PM
Pwerstrokekid's Avatar
Pwerstrokekid
NEED HELP ASAP!!
ok guys I'm new to this forum page and i need some help asap. i have a 96 F150 with the 5.8l was recent on a 150 drive down to see my parents and about 80 miles into it the check engine light came on and a pretty substantial ticking noise came about. at an idle it shakes the whole truck like crazy. i got out and it sounds like its coming from the left rear of the block closest to the driver. I'm thinking possible rod knocking? maybe a lifter stuck? need to get this fixed asap so i can get back home anything helps thanks guys.
Old Jun 18, 2014 | 01:35 PM
Flecker's Avatar
Flecker
Pull the codes, see what the engine light is pinpointing. Will narrow down the culprit.
Old Jun 18, 2014 | 02:02 PM
GoinBoarding's Avatar
GoinBoarding
It's OBDII not OBDI so he can't pull codes the way nearly everyone else on here can, however, OBDII monitors more than OBDI so you can garner more info anyway. You'll need some way to link to the data port under the glove box (should have a little black cover over the connector).
If it's shaking hard at idle, it sounds like a misfire to me. You can pull plugs on this truck with a 5/8 deep socket and regular 3/8" drive ratchet (unless they're originals and rusted in place..). Might be a place to start. Another trick is to pull plug wires one at a time and watch for a change in how it runs, if you pull a wire and there is no change, that is the misfiring cylinder. Pull that plug. Note: I'd shut the truck off before grabing a plug wire to unplug it, you don't want a 35,000 Volt shock, it hurts!
Another common problem is the coil to distributor wire being badly corroded, pull it off the coil & see if its really corroded.
When was the last tune up? How many miles & what kind of maintenance record does she have?
Old Jun 18, 2014 | 02:33 PM
kermmydog's Avatar
kermmydog
Smile
Your right but with an OBDII system you can pull into any Auto Zone & they as a rule will check it FREE.
Second if you own an OBDII System the first thing on the list to buy should be an Code Reader. Harbor Freight sells a nice $49 or $59 unit. I carry one of them & it has paid for itself over & over. Saved a lot of HELP ME. At least when I need help I have some info to provide so I can be helped.
Old Jun 18, 2014 | 02:34 PM
Pwerstrokekid
maintenance is all in good shape just about to hit 145 ok the clock. but even a mis fire doesn't explain the loud ticking. as if a rod or something is knocking,
Old Jun 18, 2014 | 03:00 PM
GoinBoarding
Could try the old wooden dowl to the ear trick (or if you have a stethoscope), to try to locate the noises origin. If its really loud, and you're certain its on the drivers side, its pretty easy to pull that valve cover and check for a broken valve spring or other issue. Hopefully its not in the bottom end..I'd be surprised if it were.
Old Jun 18, 2014 | 05:57 PM
Pwerstrokekid
ya I'm hoping it not in the bottom end. but it for sure on the drivers side rear part of the block. ill know as soon as i pull the valve cover off
Old Jun 18, 2014 | 07:02 PM
kermmydog's Avatar
kermmydog
As soon as we get a telepathic channel open, someone will be able to hear the noise & tell you what it is.
Old Jun 19, 2014 | 11:07 PM
Pwerstrokekid
well got it figured out. turns out it was misfiring and sucking so much fuel it wasn't burning fast enough so it ended up filling the catalytic converter. thanks for the help guys.
Old Jun 20, 2014 | 10:20 AM
subford's Avatar
subford
Sounds like the spark plug wire was off and the spark jumping to ground was the clicking noise and the the shaking from the #8 not firing, maybe #7.
Did I guess right?
Old Jun 23, 2014 | 12:02 PM
Pwerstrokekid
indeed you were it was #8
Bubba Jones
1978 - 1996 Big Bronco
Sep 7, 2012 05:34 PM
PatrickH
3.8 & 4.2L V6
Jun 17, 2012 11:02 AM
beauboy
1983 - 2012 Ranger & B-Series
Jan 24, 2008 02:30 PM
sprinklerguy
1997 - 2003 F150
20
Mar 19, 2007 09:57 PM
gts95
Oct 2, 2001 09:14 PM
