1978 - 1996 Big Bronco
p0304
Old Sep 7, 2012 | 01:49 PM
Bubba Jones's Avatar
Bubba Jones
p0304
Okay so after donating blood today, I stopped by Auto-zone on my way home to pick up some new windshield wipers since it was starting to rain. When I got in the parking lot, I noticed my truck seemed to have a semi-rough idle. Well, after installing the wipers in the now heavy pouring rain, I got in my truck and started her up. The idle was still rough and my check engine light was now on.
I bought a scangaugeII I mounted in my dash a while ago that read codes and it said it found 3 codes, but they all must have been p0304 because when I cycled through next codes, the listed code stayed the same.
I had to drive home on the highway and when I gave the engine a bit more gas when passing someone in 4th gear, the engine light started flashing. After I passed the other car and went back to 5th, the light stopped flashing, but still stayed on. It didn't flash the rest of the way home, but I was pretty easy on the gas.
I know that p0304 is the code for a misfire on cylinder 4. It is still raining here, so I haven't wanted to go outside to mess with the truck yet, but I'm hoping someone can point me in a direction what would help me correct the problem the fastest when I get a chance to check things out.
I know I should check the plug/wire to cylinder 4 so I'll do that first. I may not have put much di-electirc grease around the plug when I replaced them a couple month ago, so is it possible the plug end just got wet and that could set off the codes?
I have read that a leaking intake manifold gasket could also cause this, or a possible ignition coil problem that can set off misfires. I would think if it was my coil, there would be two misfires though right?
If it turns out not to be my plug/wires, I am not too savy with knowing what the next likely culprit would be.
I'm hoping it's not an exhaust problem that would cause this. I believe I have a small exhaust leak after putting on my headers, and I haven't yet purchased copper gaskets and locking bolts. Does anyone know if a possible exhaust problem could throw this code too? I just remember too, that my scangauge says my truck is stuck in open loop... so maybe that can contribute to the problem?
Old Sep 7, 2012 | 05:34 PM
Bubba Jones
Haha.... mystery solved! Now that it stopped raining and I had a better chance to actually check things out it was pretty obvious.....
With my Bassani Headers, its pretty hard to securely push in the plug wires, especially in the back. I went to pull off the #4 cylinder wire and it wasn't even attached.. the rubber boot was just resting on the tip of the spark plug. I think that probably causes some misfire. The Bassani headers are awesome, but make dealing with the spark plugs a little bit of a hassle. I still am having trouble having the wire 'snap' on the tip of the plug, but with it on there better, I could tell there was no misfiring.
I now need to find that thread that people were talking about where the bought a spark plug socket adapter they used specifically for these headers... without it its a little too hard to get some of the plugs out! Oh well I won't need to change my plugs for quite some time!
oldhokie
Escape & Escape Hybrid
Apr 1, 2022 11:34 AM
money pit 69
1983 - 2012 Ranger & B-Series
Sep 11, 2017 02:17 PM
rawdawg2
23
Jul 25, 2008 08:17 PM
ZonaNavyStar
Aug 25, 2007 11:26 PM
Black 5.4L
1997 - 2003 F150
Feb 27, 2003 07:50 PM
