Centering Pin on D44HD
Old Jun 17, 2014 | 10:59 AM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Ok so my dad has a 89 F250 4x4 351W ZF5 reg cab long bed with a D44HD front end. When we bought the truck it was involved in a T-bone accident on the road causing a lot of body damage but no frame damage luckily. We just recently were checking out a few things on the truck and noticed the centering pin for the leaf spring on the right front of the axle had broke and the passenger side traction beam has moved towards the cab of the truck more. (which is strange because the truck still goes down the road perfectly straight). Problem is I can't tell what the centering pin is being that it is broken and I can't get all the caked on dirt, mud, grease, and rust off the drivers one to see.
Is it just a stud or is it a bolt?
If it is a stud or bolt what size would I get to fix this?
This is the only problem left with the truck I need to get it done as we need to give the truck an alignment before it wears out the tires on it even more. The local shop won't fix the centering pin but we have enough experience to do it ourselves.
Thanks guys and gals
Trav
Old Jun 17, 2014 | 12:07 PM
Mike1's Avatar
Mike1
Here, maybe this will help you:
Leaf Spring Center Pin
Old Jun 17, 2014 | 12:11 PM
Redneckfordf2502002
Ok so now I know it is a bolt so now all I need to know is the exact size so I can run to the local ace and get one.
Trav
Old Jun 17, 2014 | 12:23 PM
Phy's Avatar
Phy
It's not a standard bolt, it has a round head rather than a hex...
Old Jun 17, 2014 | 12:26 PM
Redneckfordf2502002
Right I see that from the link posted above. I know I can get round head bolts with allen head screws at the local ace as I have gotten them when building my Harley. I just need to know the length and size.
Trav
Old Jun 17, 2014 | 01:20 PM
danr1's Avatar
danr1
Get a center bolt from the auto parts, ace hardware is not going to have what you need.
Centering bolt will have a special tall head and will also be fine threaded resistant to shear force, will be longer than required finished length as to aid in drawing spring pack down together, cut off excess pin once in tight.
Surely worth the little extra effort it'd take to get the correct bolt.
Old Jun 17, 2014 | 01:25 PM
Redneckfordf2502002
I already asked O'rielly they don't have it. I am not sure where to go to get it.
Trav
Old Jun 17, 2014 | 01:34 PM
danr1's Avatar
danr1
Trav
Best bet and to be sure you get the correct pin would be to take it out, measure its diameter then figure finished length you need. Order one that diameter adding couple inches to finished length or so so have little extra needed get the nut started.
If have large C clamp won't need much extra, no large C clamp or equivalent springs don't lay into one another tight? get one plenty long enough reach through all springs.
Springs that have been in a pack for long time usually lay right back into one another pretty tight.... you'll know once its apart.
Same time figure/measure for new u bolts, order them in with the center bolt.
How to measure for U bolts > http://www.wwfriedlineinc.com/measuring_ubolts.php
Old Jun 17, 2014 | 04:18 PM
tjc transport's Avatar
tjc transport
i ain't rite
and spring shop will have them in stock.
or, call Junior at ATS and he will be able to set you up with the proper bolt.
you will need new spring u bolts too.
__________________
www.ATSsprings.com
Ask About our Ford-Truck Forum Discounts! (1-888-943-8287)
"We sell parts and experience"
Old Jun 18, 2014 | 10:23 AM
Redneckfordf2502002
I left a message last night hope to hear back from him.
Trav
UNTAMND
Jun 26, 2025 10:37 AM
KsCop
Nov 19, 2013 05:23 PM
*2fords*
Garage & Workshop
May 9, 2011 04:13 PM
hdman6
May 31, 2010 11:34 AM
shoundog
Feb 6, 2008 05:49 PM
