slide pin bolt size
Old May 30, 2010 | 07:20 PM
hdman6's Avatar
hdman6
Question slide pin bolt size
I am installing new rear rotors and pads today. Everything was fine until i got to the drivers side and saw the bottom slide pin bolt is MISSING! And now the pin is almost frozen. So its memorial day weekend and i have new brakes but I need that bolt. Wht size is it? Also the pin is working fine now after i cleaned it up and re lubed it. I need to clean it out better for the bolt to go in all the way. I was using the top one to make sure it still has good threads. It seems they are just rusted up somewhat. I was hoping I could run to lowes or the hardware store for this bolt. any help would be great. Thanks Jeff
Old May 30, 2010 | 10:14 PM
MX_Fyrcaptain's Avatar
MX_Fyrcaptain
Check Guzzle's O ring site. He has a write up on the pins in his maintenance section. It may give you the info that you need.
Old May 30, 2010 | 11:03 PM
Ponyboychris's Avatar
Ponyboychris
Believe it or not, my local Checker Auto had the slide pins in stock. 2 per pack for 5 bucks.
Old May 31, 2010 | 06:25 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
O'Reileys hs the slide pins with the bolts included for 2 bucks for both wheels.
Old May 31, 2010 | 11:32 AM
rpenterics's Avatar
rpenterics
Just did my fronts and rears and got new pins and bolts from advanced auto. They are a metric bolt, if you don't have a auto parts store open just take the other slide pin bolt (they are identical top and bottom, but I believe fronts are different from the rears) with you when you go to a hardware store to match them up.
Old May 31, 2010 | 11:34 AM
jwhitetail's Avatar
jwhitetail
Take the top one with you there the same top and bottom.
1970f100guy
Apr 25, 2014 07:20 PM
SkySkiJason
15
Jul 13, 2012 09:25 AM
firedaniel
Mar 25, 2012 05:00 PM
brickie
Jul 20, 2010 10:25 AM
kawa
Mar 31, 2008 09:42 PM
