Door trigger wire
Old Jun 16, 2014 | 03:43 PM
kind153's Avatar
kind153
Door trigger wire
Installing a remote start on 2003 Navigator. I have everything working except the door trigger and dome supervision.
Searchs tell me that it is Black/(Light)Blue under the driver's kick panel. There are 5 of them with varying guage, and none of them fluctuates when all door is closed.
Please help!
Old Jun 16, 2014 | 05:00 PM
projectSHO89's Avatar
projectSHO89
What function are you calling the "door trigger"?
Old Jun 16, 2014 | 05:03 PM
kind153's Avatar
kind153
Sorry if I was unclear. I am looking to connect the following:
1. H2/12 VIOLET (+) DOOR TRIGGER INPUT (N/C* OR N/O)
2. H2/7 BLACK/YELLOW (-) DOME LIGHT SUPERVISION OUTPUT
for Viper 5704.
Thanks!
Old Jun 16, 2014 | 07:50 PM
alloro's Avatar
alloro
Look close with a light, sometimes a dark blue, brown, or purple can look like black in dim lighting. You can probe each of the BK/LB wires you find for 12 volts. It will be 12 volts when a door is open and zero when they're all closed and the interior lights are off.
Old Jun 16, 2014 | 08:56 PM
kind153's Avatar
kind153
Thank you, alloro. I had two lights...they are positively black/blue. I was hoping to see if anyone could shed a light(!).
Old Jun 16, 2014 | 10:33 PM
alloro's Avatar
alloro
My service manual doesn't show that particular connector for some reason.
Old Jun 16, 2014 | 10:45 PM
kind153's Avatar
kind153
precisely. I could not find anywhere!
Old Jun 16, 2014 | 10:54 PM
alloro's Avatar
alloro
Found it (I hope), pin 59, circuit 53.
File Type: pdf
Old Jun 16, 2014 | 11:00 PM
kind153's Avatar
kind153
wow...amazing. what is this connector going to? Is this a connector? thank you!!
Old Jun 16, 2014 | 11:10 PM
alloro's Avatar
alloro
It probably looks bigger on your screen than it will in real life. It's likely only something like 4"x2" or so. But apparently that's the one down in the driver's kick panel that you're looking for.
Old Jul 5, 2014 | 06:16 PM
kind153's Avatar
kind153
Finally had a chance to get there to do it.
It works......somewhat. You are correct that it is <i>the wire</i>, however, it is not working as I want to.
This wire is hot (+12v) when the dome lights are on. On my navigator, the light doesn't go off immediately when the doors are closed. Therefore...the alarm says "door open".
I want it to turn the lights on when UNLOCK is pressed. (Which would be H2/7 BLACK/YELLOW (-) 200mA DOME LIGHT SUPERVISION OUTPUT?)
I can see why the references are showing USE DOME LIGHT for door triggers, but not quite so. I really wish there is a wire (preferably (-)) that triggers the dome lights to turn on (and off too like factory fob...but I'll be happy with just on)
Thank you!
Old Jul 6, 2014 | 11:38 AM
alloro's Avatar
alloro
Oh...okay. In that case tap into the 'orange/light green' wire (pin 2) coming off the black connector on the main light switch. Applying negative to that wire will have the same effect as if you turned the dimmer to ON for the interior lights. See the attached PDFs for the diagram and connector.
File Type: pdf
Old Jul 14, 2014 | 02:59 PM
kind153's Avatar
kind153
Thank you alloro once again. The cable does seem to be powering up the interior lights when connected to the ground, however, I don't think 200mA is sufficient.
Is there a wire that feeds to the factory switch? (like when factory fob unlock is pressed) I'd really like to avoid using a relay if an alternative is possible.
Thanks!
MK
Old Jul 15, 2014 | 09:01 PM
alloro's Avatar
alloro
According to the wiring diagram I posted, that wire controls the ground side of the interior lighting relay. That's about as simple as it's going to get. You could connect a millamp-meter from that wire to ground to see how much power is actually being drawn. If it's less than 200ma then you're all set, if it's more than you'll need the extra relay.
Flyview
Jul 9, 2017 08:35 PM
62star
Jul 29, 2012 03:58 PM
ATC Crazy
1997 - 2003 F150
Sep 16, 2006 12:01 PM
Pagemaker
Aerostar
Jun 12, 2005 10:50 PM
