Got 'er Home!
Old Jun 15, 2014 | 10:26 PM
carchub's Avatar
carchub
Got 'er Home!
It's been two long years but I finally have my truck in my driveway. Some of you regular posters may recall me buzzing around the forum every once in a while asking questions and saying I can't even work on my truck. Well, as a graduation present, my family towed it to my place in Oregon all the way from Sequim, WA.
I just took up a job at a local auto shop so once I get registered and insured I'll be able to take it to work and work on it. First thing I need to swap out the split rims and mount my new rear-view mirror. I got so excited tonight I went ahead and fixed the horn. I tried cleaning all contact points for a sure-ground with no luck, so I went ahead and replaced the horn relay. BEEEEEEP!
My original mirror is 10" but my grandparents ordered me a $10 8" replacement from LMC. I think I'll roll with that for now, as it seems too much trouble to return it and get the right one, just need the glue. A mirror's a mirror to me at this point; I just wanna get on the road!
I also need to figure out my leak issue. I was certain that I had a tranny pan leak (C6 Auto.), but after sitting another two years (being started periodically) my dipstick reads full, cold (when it's hot it expands, correct? So do I have too much ATF in?). Anyways, I was told it leaked ATF where I had it parked but I'm starting to question it. We'll see.
New Relay installed
Soon I'll be rebuilding the carb and most likely replacing the trans pan gasket and filter
Old Jul 22, 2014 | 01:07 AM
69issofine's Avatar
69issofine
finally home
good job.
Old Jul 22, 2014 | 04:50 AM
jowilker's Avatar
jowilker
Got you out of the house and that ugly truck out of my sight all in one sweep.
ATF is red, used oil is black. If you have the FE engine 360/390 it is likely leaking from the rear of the intake and or valve covers. Check your stain color. Keep a pan under it.
John
Old Jul 22, 2014 | 08:05 AM
carchub's Avatar
carchub
Yeah it's got a pan for the time being in the driveway. I have to get some more type F still but I'm going to replace the trans. pan gasket soon. Going to drain the Torque Converter and fill 'er up with 12 quarts.
I'm also going to make a trip to see a Craigslist guy about a used radiator since mine is leaking. I have another thread about that whole fiasco.
Old Jul 22, 2014 | 11:02 AM
JEFFFAFA's Avatar
JEFFFAFA
Congrats. Glad to hear you got it where you can touch it and get your fix of Bump. Carefull with the 12 quarts though. You're doing a drain and fill. Not a complete tear down and wipe clean.
Old Jul 22, 2014 | 01:12 PM
rews2's Avatar
rews2
How do you go about draining the torque converter? Different than just pulling the pan?
Old Jul 22, 2014 | 02:33 PM
carchub's Avatar
carchub
Rews2, turn the TC until you see what is basically a drain bolt. I believe it is called a drain bung or something like that. Should be on the side facing the engine, but could be on the outer diameter
Old Jul 22, 2014 | 03:21 PM
JEFFFAFA's Avatar
JEFFFAFA
Yep. Exactly. T/Q is bolted to the flex plate (flywheel). Flex plate is bolted to the crankshaft. So to turn the T/Q you can move either the flex plate or the crankshaft from the front.
Old Jul 22, 2014 | 03:31 PM
rews2's Avatar
rews2
Thanks to both guys. I have a drip leak and want to switch out the pan gasket and do the filter too. Had a buddy tell me he torqued down his pan bolts too much and bent the pan so want to check my pan too.
Figure it can't hurt to replace all the fluid so why not drain the torque convertor at the same time.
Old Jul 22, 2014 | 03:54 PM
carchub's Avatar
carchub
Exactly what I was thinking
Old Jul 22, 2014 | 07:06 PM
orich's Avatar
orich
All steel pans & valve covers will bend the bolt hole area by over tightening the bolts.
If it has the aluminum pan or v-covers you'll crack the bolt whole area..
This is why everything has a torque rating: Right!
Orich
Old Jul 23, 2014 | 10:50 AM
rews2's Avatar
rews2
Orich
Yeah...yeah. Man I hate when I give too many details and it comes back on me. My major flaw is I "believe" that I know better than a torque wrench how tight it should be.
What's the old saying..."true insanity is doing the same thing and expecting different results"
Old Jul 23, 2014 | 12:32 PM
JEFFFAFA's Avatar
JEFFFAFA
Sounds like Washington D.C.
I've always used some brains,a palm ratchet,and my wrist as a torque wrench on pans and valve covers. Just snugging up the bolts. Then go back over the bolts a 1/2 hour later. Works every time.
Old Jul 23, 2014 | 01:44 PM
351Cleveland C4's Avatar
351Cleveland C4
For a mirror, I highly recommend a 12" parabolic clip on. I had/have an 8" mirror, and I clipped the 12" on over it. I can see EVERYTHING out the back.
They are cheap at the parts stores, and better than anything else IMO.
Sullid01
Mar 17, 2022 08:21 AM
nehuge
Apr 13, 2018 12:52 PM
minnesotafisherman
Sep 22, 2012 11:44 PM
nothercrash
Nov 6, 2010 12:45 PM
m0nkee221
Jun 29, 2008 12:33 PM
