1965 Headlight switch wiring
Old Jun 15, 2014 | 01:53 AM
w5nra's Avatar
w5nra
I have been searching for wiring info on the headlight switch didn't find much so I thought I'd post a pic of mine and some of the info that I did find.
A = This is connected to B (some said it is for a Brake switch)
B = Battery +
P = Parking lights (front park lights)
R = Running lights (rear running/park lights)
H = Headlight
I = Instrument lights (via reostat(dimmer))
D1 = These two are connected only when the **** is twisted
D2 = fully CCW (turns on dome light)
I am installing a 21 circuit E-Z Wiring Harness, so these below are what I believe will be the correct colors. Use these at your own risk, as I have not tested this yet.
B = Headlight power (Red/Black)
P = (this does not have power when **** is pulled out to Headlight) These are for some years that the front park lights would go off when the Headlights are on.
R = LF & LR Park (Brown)
H = LtBlue Dimmer Power? (color from dimmer switch)
I = Instru PNL LGT (Brown)
D1 = Dome wire from fuse block
D2 = Wire to dome light
My understanding is that the D1 and D2 is essentially the same as a door dome light switch. When any of the three (driver's / passenger / Headlight **** CCW) are closed, it makes contact and dome light comes on.
Old Jun 22, 2014 | 02:09 AM
w5nra's Avatar
w5nra
Ignition wiring - EZ Wiring harness
Now I'm on to the ignition switch.
Anyone have a schematic of the ignition switch and how this thing works?
I've used a multimeter on it but I cannot get my mind wrapped around it.
This is what is in the EZ Wiring manual.
The wires coming from my ignition switch are as follows.
Yellow = ACC
Red w/green = ON
Red w/blue?(black connector)
The back of my switch looks like this.
My questions are:
What goes on the center post? SW?
Yellow wire seems to be ACC
Top post in picture seems to be "ON" or Run
Left post must be "start"
It appears that top post and center has continuity when in ON position.
When I switch to the "start" position the top and left have continuity but not with the center post.
I had assumed (yes I know) that the center post was battery power but in "start" it wouldn't have any power.
Is there someone here that can set me straight?
I've probably missed some other tidbit of info that is needed.
Old Jun 22, 2014 | 10:03 AM
okiewelder's Avatar
okiewelder
switches
Im almost to this point in my build. I think l have a Rebel harness. Are the switches the same for the 62 and 65?
Old Jun 22, 2014 | 10:38 AM
w5nra's Avatar
w5nra
I have never heard of the Rebel harness. It looks like you got an extra $45 worth of pictures but the wiring still didn't make sense after looking at Rebel diagrams. Only slightly clearer.
This under dash stuff sucks! just sayin'
I think I have the headlight switch wired correctly, but need to double check the tail section.
The gauges seem straight forward, I'm just waiting to get the ignition completed before hooking up the gauges.
Then, what to do with all the extra wiring... haha I bought the 21 circuit harness so I can install power windows/doorlocks later and maybe have some extra circuits for my amateur radio gear...
Terry
P.S. I cannot imagine that the switches would be THAT different... but then again...
Old Jun 23, 2014 | 03:52 PM
CTom's Avatar
CTom
This might help............. 1964 Ford and Mercury Shop Manual Part 15 - Part 23 page 6 of 90
Old Jun 23, 2014 | 06:47 PM
w5nra's Avatar
w5nra
Originally Posted by CTom
Thanks Tom, I got a few schematics now that I need to peruse. Even the 1965 wire colors don't match and I'm pretty sure that the ignition connector is original. I don't know what colors I had that went to the center stud, but the original harness has a yellow, RED/green stripe, and RED/blue or black stripe. It looks like a blue stripe but the green one has a green bullet connector and the "blue" one has a black bullet connector, which I know mean absolutely nothing... or do they? haha *twilight zone music*
I did receive a bunch of schematics from another member for all of the 64 models.
When I figure out exactly what is required, I will post that info here.
Old May 18, 2020 | 06:43 AM
q8drill's Avatar
q8drill
Head light switch
B = Battery +
H = Headlight
Hello
I’m using EZ wiring 21 circuit trying to install the headlight switch same as above picture, when I got the above switch which is not original for my 59 F100 found out that A and D1 connected together. Don’t know why, have you tested the switch according to your wiring.
thanks
Ahmad
Old May 19, 2020 | 06:16 PM
Rusty Fords's Avatar
Rusty Fords
Sorry I can't help on this matter but the 2 other members on this post haven't been active since 2016. Good luck I hope someone else can jump on here and help you out.
52' fordnut
Jul 16, 2015 06:51 PM
jrockdiddy
16
May 12, 2015 10:57 AM
sere0501
Nov 28, 2014 04:39 PM
Tyler S
Apr 26, 2014 10:03 PM
broncobillyII86
Bronco II
Jan 5, 2007 02:00 AM
