Bronco II Ford Bronco II
lights on warning signal
Old Jan 3, 2007 | 04:31 PM
broncobillyII86's Avatar
broncobillyII86
I have a brown and a green wire hanging off this switch that beeps when I leave the lights on does anyone no where these attach too...TR
Old Jan 3, 2007 | 05:41 PM
kernel-panic's Avatar
kernel-panic
Are these wires hanging out of the headlight switch plastic pigtail / wiring harness connector? The only brown wire I know of is for the running / park lamps that comes off the main headlight switch. There are other wires, the only one that is green is light green with a yellow or orange stripe, I think. I don't know which position they connect to on the headlight switch, if that is where they are hanging from. Are they hanging from elsewhere? I know there is a warning beeper / buzzer for when you leave the lights on or the key in the ignition, but I couldn't track down the wiring diagram for that. If it's on the headlight switch itself, you may have to get a pigtail from Advance/Schuck's/Kragen/Checker or Autozone or NAPA or some such and go from there.
Old Jan 4, 2007 | 01:17 PM
broncobillyII86
They are hanging off the warning beeper switch itself. TR
Old Jan 4, 2007 | 06:43 PM
kernel-panic
I can't find the warning beeper in any of the wiring diagrams I have and I don't remember if it's separate from the headlamp switch. Any way you can take a picture of this and post it?
Old Jan 5, 2007 | 01:45 AM
broncobillyII86
The beeper switch is kinda on the steering column, they must run up to the head light switch most likely I guess ...Tony
Old Jan 5, 2007 | 02:00 AM
kernel-panic
I'll take a look at my rig later today sometime during the daylight and see if I can find what you're talking about.
