starting issues
Old Jun 12, 2014 | 09:51 PM
2andfour's Avatar
2andfour
starting issues
Hi there! New to the 7.3 IDI world.
I'm having issues getting my beast started. '90 E350 7.3 ambulance.
Replaced the batteries and starter (whose idea was it to put the top bolt there?), and now when I turn the key, the glow plugs run and all I get is a "click".
Any ideas?
Thanks,
-k
Old Jun 12, 2014 | 10:49 PM
2andfour's Avatar
2andfour
Update: I have tried the "wiggling the gearshift" trick....and am now trying to locate the solenoid/relay inside the passenger fender....does anybody have any pics of what this looks like?
Old Jun 12, 2014 | 11:29 PM
Macrobb's Avatar
Macrobb
It's about 1.5" diameter, sticks straight out. Has two large(like 1/4-3/8") terminals, and one smaller terminal on top. Has a wire with a rubber boot over the smaller terminal, it just slides off.
Old Jun 13, 2014 | 02:36 PM
2andfour's Avatar
2andfour
Thanks! Will give it a go!
Old Jun 14, 2014 | 06:19 PM
2andfour's Avatar
2andfour
Talking
Got it going! thanks for your help, folks!
Old Jun 16, 2014 | 03:58 AM
Johnny L's Avatar
Johnny L
The shortest ever starting trouble thread. Lol! Good work getting it going.
Old Jun 19, 2014 | 10:32 AM
2andfour's Avatar
2andfour
Johnny....as you know, we Canadians are stubborn buggers....I didn't give it a choice BUT to start!
Old Jun 19, 2014 | 12:53 PM
madpogue's Avatar
madpogue
Might be helpful to future readers (that's the whole reason for the forum format, after all....) to know what you did to get it going....
Old Jun 19, 2014 | 01:07 PM
2andfour's Avatar
2andfour
Good point.
Background: Vehicle would not start, only made clicking sound when key was turned.
First I checked the batteries, which were a little fried, so I replaced them.
I then confirmed that the glow plugs were cycling. As I don't have any way/enough patience of measuring this at the glow plug relay, I initiated the glow plug cycle while I checked out the load drain on the batteries. My rig has an ambulance package with a battery ampmeter built in to the auxiliary panel, so this was no big deal.
When this looked ok, I pulled the starter , and had it load tested at the parts store. It was, apparently on the way out. (I should mention that the starting system was the only system NOT replaced/repaired by the previous owner, so I was planning on doing this at some point anyway). I then installed the new starter, to no avail: *click*.....F$%K!
Finally, I pulled the second starter relay from inside the front fender, and violently scrubbed all connections with a BBQ brush, resealed the unit and replaced. For good measure, I removed the last of any/all corrosion from any possible electrical lead I could find with the brush, re connected it all, and said a quiet prayer.
Started better than it ever has, according to the PO (good friend who was concerned that the truck wouldn't start).
Hope that helps.
-k
***edit**** Should also mention, that I attempted starting in N, as well as while jiggling the gearshift to ensure it was not the safety switch gone awry.
BRay09
Jul 22, 2016 07:26 PM
fordint7.3
Dec 3, 2014 04:41 PM
jwlsbaldwin
Mar 28, 2013 10:30 AM
superduty86
Jan 8, 2012 08:21 PM
red_fordtruck
Nov 9, 2007 03:10 PM
