Fuel Injector Question
Old Jun 12, 2014 | 01:29 PM
Tachycardia's Avatar
Tachycardia
Hi everyone, I've used this site to research many repairs but never registered.
Anyhow, I had a question I hope to get some input on.
I am replacing the intake manifold on a 2004 Eddie Bauer 5.4 Expy, I have the new one installed and ready to proceed with the rest of the reassembly.
I installed new plugs and COPs and I am about to install the fuel rail/injectors and was wondering if it is better to replace them in a case like this?
The truck has 220,000 miles on it and they very well could be the original injectors.
I found a Bosch set on Ebay for $150-ish so just wondering if it is advisable to do so as preventative maint.
Thanks for any responses and for your time.
-Josh
Old Jun 13, 2014 | 10:31 AM
2trux's Avatar
2trux
My thought on replacing working, but old, parts: How hard is it to replace later, how bad would it be if it did fail later, and how much does it cost.
Old Jul 6, 2014 | 07:38 PM
wedo43's Avatar
wedo43
Fuel Injectors
Hi Tachycardia,
How did the install come out?
I removed mine,soaked them in berryman chemtool for a couple hours. Then I made some wire leads that i attached to the inectors 1 at a time. I refilled the injectors then connected the wire leads to a 12v battery and let them squirt it out. I then reloaded and repeated while pushing compressed air through them while powering the injectors. Finally I wire brushed the bottoms of the injectors to be sure the tiny holes were clean, then installed new o-rings top & bottom. Haven't finished putting it all back together yet but expect them to work like new.
dwdranch
May 15, 2013 07:24 AM
newr
1983 - 2012 Ranger & B-Series
Apr 27, 2010 06:43 AM
bcompton35603
Nov 30, 2009 02:10 PM
97ExpGuy
Mar 20, 2009 04:01 PM
knash0727
Sep 30, 2008 08:29 AM
