I am getting ready to replace my injectors. Is this an easy driveway job or do I need a shop and a diesel mechanic? Does anybody got a writeup on how to do it?
Yes injectors can be installed in the driveway. Be carefull not to bend the steel fuel lines because they have a inner coating that will crack and flake off and clog the injectors if bent to far. Check out the following link for how to replace the injectors. https://www.ford-trucks.com/forums/7...-any-help.html
Also it is a very good idea to have your new injectors pop tested and adjusted if necessary before you install them.
Good luck.
Jim
Well I got my injectors and got them pop tested. I was told that they were good. I installed them and no more leaking... Whoop! Now though it runs rough at idle.
I cracked the lines and waited to see fuel. Then I got the truck started and it was running rough. I figured that it was air in the lines, so I cracked them again and saw fuel coming out. Did I miss something or do I need to bleed them longer?
you ma try to crack the lines one at a time wen eng is running if it gets worse then that one is working if no change then I would pull that one and get it re tested. I replaced one injector this year the new one was no good I was lucky we tested it before it went in .
Just my 2 cents worth
Butch
did u replace the return lines and plastic caps as well? when i did the injectors on mine i had air in the system and i was test driving it, the truck wouldnt go down when i shifted from 3rd to 4th lol. after the air worked its way out it runs like an animal.
