My Turn
Old Jun 9, 2014 | 04:48 PM
just another truck's Avatar
just another truck
My Turn
So, you know that issue that always comes up about someones truck just shutting down when it rains..
Its my turn, anyways, before I go digging around the site to hard, to look behind the fuse panel, do I have to remove it.. Yes I know I should look, but I dont get to spend any damn time on this site anymore.. sadly.
Yes, it sets a code, no, I have NO way to read it.. Insert DP tuner add here for their new infinity, or an add for a new laptop with Auto Engnuity
Old Jun 9, 2014 | 05:00 PM
HKusp's Avatar
HKusp
Do you have an Android phone?
Old Jun 9, 2014 | 05:30 PM
GreenTerracePSD's Avatar
GreenTerracePSD
Definitely check behind the fuse panel. My truck was acting weird when it rained and I found a leak on the driver side column and the water dripped right on top of the fuse panel/GEM and that is what was causing my symptoms. I took it out and took apart everything. Dried everything and use de-electric grease and made sure not to let water leak on it again and no problem since last year.
Old Jun 9, 2014 | 07:12 PM
just another truck
No Sir, i PHONE, Are we able to read anything if I buythe right cable, AND will it read with a DP?
Thinking about just going to a windshield joint and havingthem reseal the window.
Old Jun 9, 2014 | 08:02 PM
F350-6's Avatar
F350-6
Your truck is a little long in the tooth to be worried about a windshield that wasn't sealed right way back when.
What CPS do you have in the truck, and is it the rain or the windshield wipers that cause the problem? A CEL tells me to check the CPS first.
Old Jun 10, 2014 | 01:40 AM
Firefighter 1406's Avatar
Firefighter 1406
Hey Pat great to see you again. I wish I had some help for you. If you were closer I would offer scanning it with my AE for you.
Old Jun 10, 2014 | 06:07 AM
just another truck
Damn, I posted this morning, early, and I don't see it now. Anyhow, Seth, never mind the AE, it would be nice if you were close enough just to have a beer.
Good call Chris, I read your post and drove to work with the wipers on, sure enough, truck stumbled several times. So, I guess replace the wiper motor before tomorrow's all day rain.
Old Jun 10, 2014 | 07:24 AM
Firefighter 1406
I am glad you got it figured out. Beer sounds great!! Maybe one of these days.
Old Jun 10, 2014 | 07:31 AM
Tugly's Avatar
Tugly
In answer to your iOS phone - WiFi OBDII adaptor (no cable) and Dash Command will read a lot of the stuff in our trucks, but I haven't found IPR yet.
bart f-350
Apr 25, 2016 06:34 PM
nlfireblade
2004 - 2008 F150
Feb 25, 2009 10:32 PM
ISUsuperduty
Dec 15, 2005 07:54 AM
da1gamer
Dec 25, 2004 03:52 PM
da1gamer
Dec 25, 2004 09:01 AM
