Flareside bed ?s
Old Jun 9, 2014 | 02:48 PM
GaMachinist's Avatar
GaMachinist
Flareside bed ?s
How bad would it be to put a '72 or older bed on a '79?
Is there that much difference in the two other then the top rails being tilted compared to flat, and the spare tire mount on the side for the older ones?
Old Jun 9, 2014 | 03:50 PM
-mywheels-'s Avatar
-mywheels-
72 bedsides have a bump. Also known as one of the bumpside generation. 73-79 have a indented channel running along the body. Also known as a dentside. You can do whatever you want, but it won't look right.
Just saw that you posted about flaresides. Nevermind.
Old Jun 9, 2014 | 03:53 PM
GaMachinist
The Flareside beds, also known as "Step Sides", don't have the bump or dent.
Just the Fleetside beds do.
Old Jun 9, 2014 | 04:09 PM
crazy_urn's Avatar
crazy_urn
I would also be interested in knowing if the older beds will fit. I have a 77 LWB flairside with a bit of rust. Wondering how hard it is to find a replacement.
Old Jun 9, 2014 | 04:25 PM
GaMachinist
I don't think I've ever seen a long wheel base flareside in the older model. I have seen it for the 73-79, but not the older ones.
Old Jun 9, 2014 | 04:59 PM
Arbiter's Avatar
Arbiter
I have a 67 that someone placed the body on a 73-79 frame.
There is a 2 inch increased wheelbase length on the 73-79 frames in comparison to the older frames, hence if you place an older bed on a newer frame, you will have this 2 inch increased gap between the cab and the bed.
It would make more sense to use a 73-79 flareside bed on the newer frame to avoid this gap and the associated problems of re-drilling the bed holes and weakening it.
Hope that helps some.
Old Jun 10, 2014 | 05:01 AM
ZanyZane's Avatar
ZanyZane
Trailering
My bed is pretty shot and I was also trying to find a new bed or replacement parts. LMC make a kit for the wooden bed, but I'm having a hard time finding the fenders and tailgate.
I like the color of your truck... is it original?
Old Jun 10, 2014 | 12:17 PM
GaMachinist
I honestly haven't checked. I know there is a color similar to it on the Ford paint chart for '79. My bed is pretty bad around the mating parts for the pillars and panels, the fenders are good except under the steps, and my tailgate is past saving.
Big thing I've learned now that is if the wood bed doesn't have the metal trim and has gaps for dirt to fall through the cross members under the bed, the upper shock mounts, and gas tank are holding all of the dirt that falls through. I'm going to have to replace all of them and hope my frame isn't damaged too much!!
Old Jun 10, 2014 | 07:40 PM
tbear853's Avatar
tbear853
Don't you just hate when that happens ..... ?
... etc ...
I wonder if the 2 inches is under the cab or under the bed? I believe it'ld be easy to compare bed mount holes to cab back wall distance and determine where the 2" difference is .... it may be in the cab mounting?
I've seen earlier fenders (looked same from early 50s through '79) used with some steel sheet to make an almost original looking flareside, the guy just made it a few inches wider so the outer edges were same width as front fenders. Made bed floor of diamond plate steel sheet and finished top of sides and head board with some round steel tubing. I think the two fenders were the only Ford parts used. Looked heavy enough, and heavy duty enough as well.
I've thought that would be the way I'ld go before going flatbed .... if I did either.
Old Jun 11, 2014 | 02:25 PM
Arbiter's Avatar
Arbiter
It's the wheelbase, they stretched it 2 inches when they introduced the 73 model line, which in turn, makes your bed sit back farther.
The cab is fine, it's the 2 inch gap between the cab and bed you get from using this newer frame.
On a 67-72 model short bed, I figured that if one used a flareside bed from a 73-79 along with the cab, it would take up the 2 inch gap, but I have never wanted to try it since I'm in the planning stages of restoring a different truck than my 67.
There is also the possibility that one could modify the frame instead of drilling the truck bed?!? That way you had the best of both worlds, the original bed holes and the new ones. Could possibly take a little welding in areas of it.
Old Jun 11, 2014 | 02:34 PM
GaMachinist
I like the idea of building a flatbed with removable flareside sides!
Make it where the sides and fenders are one piece and can be removed leaving the bed and "headache board".
I'll have to look into that and see what it would take and look like.
johnboy427
Aug 16, 2009 10:03 PM
mxhowes1
Mar 16, 2008 03:28 AM
keyul
Dec 5, 2007 09:10 PM
SBrown732
Sep 1, 2007 12:32 AM
wvmudder
Paint & Bodywork
Jun 9, 2004 05:11 PM
