Sponsored by: Real Truck
Front spring help
Old Jun 9, 2014 | 01:14 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Front spring help
Hey guys I am working on a 2001 Ford F-350 DRW with 40,000 original miles on it. The owner put on a aftermarket Reunel bumper on it with a winch and when he puts his camper in the bed he says the front sags pretty bad especially when he hangs his quad off the front of it. If I am reading the door code correctly I believe the truck has V codes currently. I want to throw some X codes under it but wondering if it will ride to harsh unloaded. I will also be installing some Bilstein at the same time.
So based off the vin tag it has V codes correct?
Old Jun 9, 2014 | 01:21 PM
Kdr358's Avatar
Kdr358
Yes, V front C rear. Personally you can't go wrong with x codes. Since you have a heavy bumper and winch the ride won't be much different. The added weight of the diesel and all the extras won't make the truck sag.
I had X codes in my old 7.3 excursion and a 400lb ranch hand bumper on the front and it rode great.
Make sure you only go OEM replacement or ATS. Any other aftermarket spring is junk and have an actual lower weight rating.
Old Jun 9, 2014 | 03:36 PM
weekendwarriorfsw32
Master of Strokes
Perfect, does any one have the part number for x codes?
Old Jun 9, 2014 | 05:04 PM
weekendwarriorfsw32
Master of Strokes
Also Does any one know what length the front shocks need to be with the 2 inches if lift I will get from this?
Old Jun 9, 2014 | 05:22 PM
LeoJr's Avatar
LeoJr
My notes taken from another thread say 2C3-5310AFA for front X codes. Hopefully someone will confirm.
housedad
Aug 28, 2018 02:05 PM
icecold
Jul 12, 2015 05:43 PM
icecold
May 1, 2015 01:15 PM
Tinman27
Feb 24, 2014 11:14 PM
icecold
Feb 23, 2012 06:32 AM
