Vehicle Speed Sensor
Old Jun 8, 2014 | 03:43 PM
switchdr's Avatar
switchdr
Got An issue with the speed sensor in a 1993 E350 motor home.
Sometimes the the speedometer needle fluctuates wildly.
Also this causes it to shift roughly & sometimes it dies when attempting to back up.
Where is the VSS located on this truck & could it be just a bad connection?
Randy
Old Jun 8, 2014 | 08:42 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It could be a bad sensor, a bad connection, or a damaged wire.
The sensor is on top of the differential on the rear axle.
Old Jun 8, 2014 | 09:40 PM
switchdr's Avatar
switchdr
Thanks,
I'll see what I can determine tomorrow.
At least I'll know where to start looking.
Randy
Old Jun 9, 2014 | 12:52 PM
baddad457's Avatar
baddad457
Could also be the PSOM inside the speedometer cluster gone bad. That will play havoc with the transmission's operation.
Old Jun 9, 2014 | 01:17 PM
Mark Kovalsky
Good point. I keep forgetting about the PSOM. Maybe it's my mind trying to forget bad things....
Old Jun 9, 2014 | 03:05 PM
JWA's Avatar
JWA
Oh yeah---discovered that my own self. Cluster assemblies from different years are most often NOT compatible!
Old Jun 10, 2014 | 07:43 AM
richter roxs's Avatar
richter roxs
bouncing speedo
A bad speed sensor of my 1996 e150 caused my speedo to bounce. when i changed it the bounce went away . i also had the problem of the van stalling when put into reverse . after i gave the van a complete tune up the stalling went away. good luck . lets us know what the fix is . thanks
Old Jun 10, 2014 | 09:54 AM
subford's Avatar
subford
True but the speedometer head and the PSOM are the same from 1993-1996 for the E & the F-series trucks.
The 1992 may also work.
The speedometer head in most vans will go to 85mph where the truck go to 80.
You can also copy the mileage and calibration from you old PSOM to the new one if you are a electronics technician with a computer and a EEPROM programer.
Old Jun 10, 2014 | 02:35 PM
switchdr's Avatar
switchdr
Thanks for the help.
Couldn't see any damaged wires & the connection looked good, so I replaced the Speed sensor on the rear end & cleared the trouble.
Randy
Old Jun 11, 2014 | 05:46 PM
VannerDude's Avatar
VannerDude
Awesome! I love it when the resolution is posted!
Old Mar 21, 2016 | 02:42 PM
Thunderpunch's Avatar
Thunderpunch
Vehicle speed sensor location
I have a 95 E350 Winnebago. And I lost speedometer and odometer with hard hitting since I lost OD. I bought the part but can't locate the sensor. I replaced the little sensor in the rear end for safe measures because my abs light was on aswell but this one I think goes to the speed cable into the tranny. Just can not find it. Thanks for any help
Old Mar 21, 2016 | 02:48 PM
Conanski's Avatar
Conanski
On a '95 the speedo isn't normally cable driven it's all electronic, is the ODO on your cluster LCD or is it the old rotating mechanical thing?
Old Mar 21, 2016 | 02:51 PM
Brian1971f100's Avatar
Brian1971f100
I had a similar problem on my 95 f150. Had to change the speedo cluster
Old Mar 21, 2016 | 05:24 PM
subford's Avatar
subford
You have no speed cable. The one you replaced on the rear end is the only one you have for a speed sensor.
It sounds like you the E4OD transmission and their is no sensor on the transmission other than the range sensor.
Did replacing the speed sensor turn off your ABS light?
Do you still have shifting problems?
Old Apr 5, 2016 | 11:16 PM
Thunderpunch
Wanted to say you were right on only one sensor. I replaced the cluster with a used one since they are no longer sold new. And alomost everything is back to normal. Including smooth shifting. Just the abs light comes on at times but really not a huge concern for me could be the abs module.
Flatbed 97
Electrical Systems/Wiring
Mar 10, 2018 04:46 PM
LonnieD
Sep 22, 2010 01:18 PM
herreraxto
1983 - 2012 Ranger & B-Series
Sep 15, 2007 12:03 AM
RyanJake
29
Feb 23, 2007 09:05 PM
nanufree
Dec 19, 2005 12:33 PM
