Shift Linkage Spring Clips/Retainers
Old Jul 8, 2003 | 02:36 AM
cashs66's Avatar
cashs66
I lost one of the spring clips that retain the tranny shift linkage rods in the column shift levers and cannot find any source for the little buggers on this forum or any other. '66 F100. Help!!!
Old Jul 8, 2003 | 06:45 AM
barry's Avatar
barry
Have you tried your local Ford dealer? Most dealers still have some on the shelf, as they came in boxes of 25, and once the package was opened, you can't return it to Ford.They'll gladly sell you a few.
Old Jul 8, 2003 | 04:08 PM
44dwarf's Avatar
44dwarf
Any auto parts store will have them in a "Hurst" shifter parts kit.
The clips are the same the bushings might even fit.
44
Old Jul 8, 2003 | 04:35 PM
Rosati's Avatar
Rosati
An old temporary fix was to install a washer and push a galvanized nail throught the hole and bend the ends up opposite of each other so it will not fall out. Works pretty good as I never replaced mine in my old Gmc pickup for 4 years.
Old Jul 14, 2003 | 01:35 AM
cashs66's Avatar
cashs66
I found the answer to my problem when I had to remove the adjustment blocks at the bottom of the shift rods (tranny end) to increase the rod length. Someone had replaced the spring type retainers with "C" clips, the type of clips one would normally use for brake shoe adjuster retainers. I installed a new "C" clip and I was in business.
75BigBlock
Dec 16, 2016 07:42 PM
dmccorkle911
Aug 24, 2014 04:35 PM
sonny1965
May 25, 2014 06:45 PM
Nothing Special
1966 - 1977 Early Broncos
13
Nov 11, 2013 09:53 PM
connork
Aug 3, 2013 09:43 PM
