I have a Borg warner t-86 (3 speed on the column) and when I pulled the trans one of the little spring clips that holds the linkage onto the trans arms one of em broke.
I went to Napa they don't carry it..
Any idea where I can get one??
Check LMC i got some clips, bushings ect. for the 3 speed column linkage for a 73. They were not like the originals but they did work, that was about this time last year.
I have a Borg warner T-86 (3 speed on the column) and when I pulled the trans, one of the little spring "C" clips that holds the linkage onto the trans arms broke. T-86: 3 speed manual with overdrive, not installed after 1964.
Look on the Warranty Plate for the TRANS code, it'll probably be a C (Ford type 3.03).
Warner T-85N: 3 speed manual w/Overdrive (non syncro 1st gear) trans optional in 1965/71 F100's (TRANS code B).
Ford type 3.03 3 speed manual all syncromesh trans standard equipment: 1963/83 F100/250, 1975/86 F150 (TRANS code C).
379620-S100 .. Spring Steel "C" Clip ~ Retains shift rods to trans levers and to the two manual control selector levers at the bottom of steering column / Obsolete
MANDERBACH FORD in Temple PA has 11 = 610-929-3683.
ROBINSON FORD SALES in Calexico CA has 13 = 760-357-3141.
RED TAYLOR FORD in Corning AR has 53 = 870-857-3518.
CARPENTER NOSOBSOLETE PARTS in Concord NC has 689 = 800-476-9653.
