Aligning Headlights
Old Jun 5, 2014 | 07:59 AM
greenmachine55's Avatar
greenmachine55
Aligning Headlights
Is there an easy way to align your headlights, low and high beams, against the wall or garage door? I have a 1955 F250. Thank you for all responses.
Old Jun 5, 2014 | 10:19 AM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
Here's what Popular Mechanics has to say about it:
How to Adjust Your Headlights - Aim Your Headlights - Popular Mechanics
edit: After reading the article, I realized they made something simple as complex as they could.
Old Jun 5, 2014 | 01:55 PM
Rimrock F1's Avatar
Rimrock F1
Here is a fairly simple article on how to do it.
https://www.coolbulbs.com/HID-VISUAL...-PROCEDURE.pdf
If you still have trouble give me a call and I'll see if I can help.
Old Jun 5, 2014 | 03:46 PM
drptop70ss's Avatar
drptop70ss
I use my 2 car garage with the doors down. Park a known good car with the lights on and shining on one door and the "project" car facing the 2nd garage door with the lights on. Align the lights so they match the focus point of the good car and good to go. Has worked perferct for me so far.
Old Jun 8, 2014 | 02:42 PM
arctic y block's Avatar
arctic y block
Ya can buy an inexpensive tool at most parts stores. Or borrow one. It
just snaps over the head light and gives a straight solid beam to adjust.
If ya can look at the tool at the parts store ya can go home and do the
same damn thing with Gorilla tape.
Old Jun 11, 2014 | 05:39 AM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
The quickest way that I have found is park I'm on a level piece of ground at about 15-20 feet away from a wall. On a 55 you need to remove the trim ring on the headlight so you can get at the adjusting screws then adjust the beam so that the center portion of the light on the wall is at the same height or just slightly lower than the measured heights of the headlamp from the ground. That will be for your up and down adjustment. For your left to right adjustment what I always do is stand at the back of the vehicle look down the edge of the vehicle and on the respective side make the right headlight slightly right off it's mounted location in the vehicle and the left headlight same thing, that way it lights up the edge of roadway on the low beams and not into the eyes of oncoming drivers.
Skalywag
Jul 10, 2014 12:11 AM
sweetlou1
Mar 18, 2013 12:53 PM
ALF1999
Sep 28, 2012 08:18 AM
WyattSmith529
1978 - 1996 Big Bronco
Nov 21, 2010 04:56 PM
CO4x4SD
Jan 13, 2003 04:58 PM
