Aiming headlights ?
Old Sep 27, 2012 | 08:04 AM
ALF1999's Avatar
ALF1999
Aiming headlights ?
I installed a new set of headlights in my early 99. I was hoping you guys could give me some tips for properly aiming headlights.
Old Sep 27, 2012 | 10:59 AM
Franko72's Avatar
Franko72
Molon Labe
I used a garage door to get mine somewhat even, then found a dark flat parking lot at night and made my final adjustments. They may not be in spec, but they are right where I want them.
Old Sep 27, 2012 | 11:11 AM
arcticatdan's Avatar
arcticatdan
I also use the garage door. Then if i get on comming cars flashing me I adjust them till no more flashing. Seems to work great.
Old Sep 27, 2012 | 11:51 AM
kell104's Avatar
kell104
Like others have said, garage door. I thought I had mine spot on but everybody was flashing me at night (with their lights, get your mind out of the gutters) so I just went down a few inches and was right on.
Old Sep 27, 2012 | 03:33 PM
helifixer's Avatar
helifixer
call the local body shops they have the equipment to set them right. and from my experience they don't charge that much
Old Sep 27, 2012 | 03:43 PM
SpringerPop's Avatar
SpringerPop
I use a bath towel.
I drive my car down a level, flat street until I know I am headed directly down it.
I then flip on my high beams and cover one of the headlights with the towel, leaving only one to aim straight down the street, illuminating everything as far away as possible.
Then I move the towel to the other side and do the same thing, and then remove the towel.
Then I flip on the low beams to ensure they are going down and to the right.
If it looks like they are still throwing too much light to the left, or too high, I make some small adjustments, but it usually isn't too extreme.
Flipping back and forth a few times will give you an idea of whether they are right or not.
I don't have people flashing theirs at me to indicate they are mis-adjusted, so I must be close.
Pop
Old Sep 27, 2012 | 06:28 PM
ALF1999's Avatar
ALF1999
Thanks Springer Pop I`ll give that a try!
Old Sep 28, 2012 | 12:08 AM
kawcrasher's Avatar
kawcrasher
This is the best way I have found.
Pull up as close as you can to a wall. Mark the center of each light on the wall. Back off 25 foot, then adjust each light to be centered on the mark and the top of the light beam 2" below the mark.
Old Sep 28, 2012 | 08:18 AM
Supercab's Avatar
Supercab
Wink
I had an interesting experiance a while back with a body shop doing mine.
Their shop is kinda small, oriented towards small import cars, they pulled my CC 8' bed DUALLY in there and adjusted the lights-mind you the rear wheels were outside the shop on the slope.
When I turned my lights on later they were shineing about 5' in front of the truck.......no lol!
Errk20
Jun 26, 2017 09:41 PM
sweetlou1
Mar 18, 2013 12:53 PM
kdy72601
Mar 17, 2009 12:14 PM
charliedana
Nov 12, 2008 08:18 PM
ohiowhitetail
General Automotive Discussion
Oct 26, 2004 07:32 PM
