Turbine wheels
Old Jan 31, 2018 | 06:28 AM
  #46
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Thanks, I wheel and deal on Craigslist...
Old Jan 31, 2018 | 08:56 AM
  #47
Aaron-71's Avatar
Aaron-71
IIRC, 15" wheels require a bit of "massaging" to get them on a 2wd truck.
Grinding down some brake parts is likely required to get them to clear.
Sweet looking rims though! That's a heck of a find
Old Jan 31, 2018 | 09:56 AM
  #48
77&79F250's Avatar
77&79F250
If you put them on a older 2wd with front drums brakes it might be ok?
Old Jan 31, 2018 | 10:06 AM
  #49
rob8210's Avatar
rob8210
I have never heard of 8 lug 15 inch wheels. Mine are 8 lug 16.5”. Not very easy to find!
Old Jan 31, 2018 | 10:11 AM
  #50
77&79F250's Avatar
77&79F250
I went to buy them off Craigslist thinking they were 16.5, yes I was shocked to see they were 15". I had to get them, even though they will not fit anything I have (77-79 4wd F250 with duel piston front brake calipers)...
I did not mean to HJ your thread Erik, I just wanted to show that there are some odd rims out there.
Old Jan 31, 2018 | 11:20 AM
  #51
fordguy2100's Avatar
fordguy2100
No worries, it's not my thread, eaglechief resurrected this one from the dead lol
Old Jan 31, 2018 | 11:33 AM
  #52
77&79F250's Avatar
77&79F250
I have feed a zombie thread before. lol
Old Jan 31, 2018 | 12:28 PM
  #53
Lds79ford's Avatar
Lds79ford
Senior Master
wish I didn't sell mine
Old Jan 31, 2018 | 12:43 PM
  #54
swampthang's Avatar
swampthang
Are these of any use? Seen them on craigslist. Shame there not a matching set. https://stlouis.craigslist.org/wto/d...398453181.html
Old Jan 31, 2018 | 06:26 PM
  #55
SlikWillie's Avatar
SlikWillie
Anyone ever seen some Shelby Cal 500 8 lug slotted mags that are 15 x 7 and 15 x 8.5....YES I said 8 lug and 15" anyone? Probably go on a 2wd?
Grandpa had those exact wheels on his '75 HiBoy with D44 drums up front. After he replaced the the D44 with a D60 disc brakes from a '79 he had to run 16.5" wheels. Nice find, though. I would call them rare.
Old Jan 31, 2018 | 07:23 PM
  #56
77&79F250's Avatar
77&79F250
Here is a set...AKH Vintage Wheels - Ellensburg Washington
I am pretty sure they are asking $900 to 1K for the aluminium spokes below? I think I called and asked them along time ago when I was going to sale mine.
I sold mine to a FTE member quite a while back. And no I did not get no where near $900 or 1K for them. I wish I would of not sold them, that is for sure.
I almost want to contact the St Louis guy and get those. Odd that one has a different a different off set. And if that are for real 16.5's... 16" tires WILL NOT fit on them.
Old Jan 31, 2018 | 08:41 PM
  #57
somethingclever's Avatar
somethingclever
Aluminum spokes are where it’s at!!
I passed on a set 5 yrs ago for 300 and still kick myself for it.
They are RARE.
Old Feb 1, 2018 | 08:31 AM
  #58
Aaron-71's Avatar
Aaron-71
I don't find the offset weird at all.
I had a set of spoke (5 bolt pattern) steelies on my 2WD truck I started rebuilding then sold. They had a different offset because the tires in the front and the tires in the rear would line up perfectly with the body lines.
When you looked under the truck, I believe the tires were offset and did not track perfectly on each other (front to back). However... the box wheel well (exterior face) to the tire and the front fender (exterior face) to the tire looked uniform.
Hard to explain... but it made the truck look better. If you look at photos of Dentsides with stock rims/tires, the rear tires look "sunk" into the box wheel well. The different offset eliminates that.
I can't recall which offset went where, but it's pretty easy to figure out lol.
Old Feb 1, 2018 | 08:59 AM
  #59
swampthang's Avatar
swampthang
Thinking about the link I posted on the aluminum spokes. 1 wheel has more offset. Think about this on a highboy it seems like when you put taller tires on they rub on the steering valve thing on the drivers side when turning right hard. Maybe put the wider wheel on that corner would help?
Old Feb 1, 2018 | 09:21 AM
  #60
fordguy2100
So weird thing happened yesterday. I mounted all of the rims rich gave me and crazy one rim didn't have clearance issues... but boy is it too close for comfort. I suppose you could shave the steering knuckle to fit but I just don't like the idea of that. Here's a video to show the differences. 1 clip is the rims not clearing, 2 and 3 clips is the one odd ball rim that clears and 4 clip is the 18 spokes clearing with no issue.
