Help Please 96 Sat 4 a while
Old Jun 2, 2014 | 10:26 PM
fordpride's Avatar
fordpride
Old Jun 2, 2014 | 11:07 PM
KINGDAR's Avatar
KINGDAR
Thanks fordpride I should have known this wasn't going to be easy, or cheap. I'll pull the injectors and check O-rings in the morning. Should I recheck my pressure after that?
Old Jun 2, 2014 | 11:25 PM
fordpride's Avatar
fordpride
If you pull the injector you're going to want to replace the orings before you put them back.
Clay at Riffraff diesel has a good peice on them.
Yes after oring replacement you'll want to check psi again.
If you have bust orings you'll see the easily
Old Jun 3, 2014 | 12:16 AM
KINGDAR's Avatar
KINGDAR
Thanks again fordpride, I ordered the O-rings from Riffraff and will do as instructed. Thank you all again. I'll update when I get Parts and finish the install.
Old Jul 25, 2014 | 01:58 PM
KINGDAR's Avatar
KINGDAR
Ok after another hiatus I've got the new O-rings installed on all the injectors and cleaned 'em up. While cranking my ICP pressure goes up to 203 psi then after a bit longer it jumps up to 2750psi but still no start. I'm thinkin HPOP. If I put new O-ring kit in it will that possibly fix it or do I need to buy a new one?
Old Jul 26, 2014 | 09:01 AM
fordman67's Avatar
fordman67
How did the orings look?
Its better so I would think they looked terrible.
You will crank it for what seems like alifetime when doing them.i ran the batteries dead 3or4 times before it tried.I'm thinking b patient.you may be onto something.it will prob keep improving until it fired.keep monitoring for the increase.
Old Jul 26, 2014 | 02:03 PM
KINGDAR's Avatar
KINGDAR
Actually they didn't look all that bad and it seems weird that it will build to 203 psi stay there a while and then jump to 2750psi which is full throttle pressure w/ truck running if I'm recalling my information right.
Old Jul 26, 2014 | 08:00 PM
fordman67's Avatar
fordman67
275 and it runs? How are you measuring that? ICP have oil in the connector? Ever have IPR out to check orings?
Unplug ICP and attempt to run? Any better...?
Old Jul 26, 2014 | 08:33 PM
KINGDAR's Avatar
KINGDAR
No 2750 psi and it still will not start. I'm using a ScanguageII, The IPR is new. Where is the ICP sensor located and then just unplug it?
Old Jul 26, 2014 | 09:32 PM
fordman67's Avatar
fordman67
Drivers head at the front.3wire sensor.unplug it.also look in where the wire plugs in.if it has oil in there then its deff on its way out.if it starts better when u unlpug then it may be giving a bad signal
Old Jul 27, 2014 | 12:35 AM
madpogue's Avatar
madpogue
Have you confirmed that those Xgauge codes are correct by using them on a running OBS truck? I've tried the "Ford 7.3 diesel" Xgauges listed on SG's web site, and they don't make a distinction between OBS and SD, and I'm pretty sure those codes are only for the SDs. They specifically list the OBS PSD as not a compatible vehicle. 'Course, that was some months ago; perhaps someone has since come up with XGauge codes specific to the OBS.
Old Jul 27, 2014 | 07:07 AM
oldbird1965's Avatar
oldbird1965
After a injector change, its going to take a long time to fire because of air in the lines. I ran mine 160 miles and it was still hard to start.
96F150-4.9
Sep 26, 2016 12:08 AM
1996fordf-150
Oct 10, 2014 01:03 PM
stsscott
Jan 9, 2014 11:54 AM
hs15760
Nov 8, 2013 07:54 AM
___
Aerostar
16
May 7, 2009 08:00 AM
