Coarse or Fine Thread Studs?
Old Jun 2, 2014 | 09:52 AM
atruscott's Avatar
atruscott
I need to replace my front passenger wheel hub assembly on an '04 6.0 4x4 Excursion. Looking through the various options I've seen both fine thread and coarse thread studs. I don't want to order the wrong part, and if I just guess I most certainly will. How do I figure out which type of thread to go with?
Old Jun 2, 2014 | 10:24 AM
9228.bobcat's Avatar
9228.bobcat
My 04 ex is course thread. Should be able to tell just by looking at them.
Old Jun 2, 2014 | 12:50 PM
atruscott's Avatar
atruscott
is Master Pro good quality or should I go with a different manufacturer?
Old Jun 2, 2014 | 01:15 PM
WatsonR's Avatar
WatsonR
my 04 truck was fine thread. The difference was $150 from course to fine. Just pull a lug nut to verify.
If you order on line from Advanced auto, then pick them up... use TRT30 in the coupon code and get $50 off the price. If that doesn't work, Google coupon codes and use one of them.
Don't forget to check the pins on the caliper bracket. Mine were froze. They sell them there as well, but the bracket, pins and boots are all sold separate.
I used Federal Mogal
Old Jun 2, 2014 | 10:48 PM
lupuseven's Avatar
lupuseven
for 100% reassurance measure them ridge to ridge
1.5 mm = fine
2.0 mm = course
I measured two threads for easier reading
3.0 mm = fine
4.0 mm = course
My early 04 p/u was fine thread
******** charset="UTF-8" src="chrome://hdv/content/hdv.js" type="application/javascript">*********>
Old Jun 2, 2014 | 10:51 PM
9228.bobcat
If all else fails and you get the wrong one just knock out the studs and swap them out with your old ones.
Old Jun 5, 2014 | 03:12 AM
atruscott's Avatar
atruscott
Turns out mine was fine thread. I jacked up the front end and then cut the wheel so I could easily get to the back side of the hub assembly. You can pretty easily see the last 1/3" of the retaining studs in questions. They were clearly fine threads and not coarse, just by looking at them. Thanks for all the replies.
quicker1
Jun 18, 2019 12:55 PM
fire240
Delaware Chapter
1194
Feb 23, 2008 07:50 PM
Chipmm
Car/truck Buying Advice
Oct 26, 2004 08:11 AM
bob-63-292
Garage & Workshop
16
Jan 13, 2004 09:32 PM
