Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Thread die or chaser?
Old Jan 9, 2004 | 11:06 AM
bob-63-292's Avatar
bob-63-292
newbie question
What is the difference between a "thread chaser" and a "die"?
I can buy tap and die sets everywhere, but get strange looks when I ask about thread chasers. Are they the same as a die? If not, does HF or Sears (or ...) carry them?
Bob
Old Jan 9, 2004 | 11:49 AM
F150daniel's Avatar
F150daniel
thread chasers clean the threads.
a die or tap cuts threads.
both pretty much the same to me.
maybe theres some difference in ther hardness or shape.
I don't know the difference. i think jegs or summit has them.
but i have a toolbox full of taps so i don't need a thread chaser.
Old Jan 9, 2004 | 01:59 PM
tigerman's Avatar
tigerman
I'm no mechanic, but I think "thread chasers" are flat at the tip; whereas, the taps are pointed at the tip so the can get started in a hole that's untapped.
Old Jan 9, 2004 | 02:02 PM
bob-63-292's Avatar
bob-63-292
Guess I should have been more specific... I need to clean up the shock mount bolt on my rear axle, which is why I was talking about a die instead of a tap.
So, being more specific, what is the functional difference between an "outside thread chaser" and a "die"?
I think I can use my die, but under the risk of removing a bit of thread if I'm not very very careful (?????)
Bob
Old Jan 9, 2004 | 02:12 PM
Mike W's Avatar
Mike W
I have a set that I bought at Sears long ago. The outside is hex shaped so a socket will fit. That may be the only difference.
Old Jan 11, 2004 | 12:49 PM
Roger Carter's Avatar
Roger Carter
Typically, a thread chaser is designed to clean, or chase, existing threads. They are not designed to cut new threads. I don't know if it is the hardness or quality of the steel or if the difference is in the design of the teeth. might ba a little of both.
Roger Carter
Old Jan 11, 2004 | 02:23 PM
otto's Avatar
otto
you can buy a thread chasing file also, which is sqaure and has about about 8 common threads per inch specific bolts
Old Jan 12, 2004 | 04:05 AM
Torque1st's Avatar
Torque1st
Posting Legend
You can get those files in English and Metric
Old Jan 12, 2004 | 07:26 AM
Kikko's Avatar
Kikko
Quote "You can get those files in English and Metric
And you can get hose files either "left or right handed"
Old Jan 12, 2004 | 08:51 AM
BLK94F150's Avatar
BLK94F150
Are the tap and dies from Sears an good for making threads. If not, who's are. Been considering a set and want something that will last. THis is for hobby use not commercial/industrial.
Mike
Old Jan 12, 2004 | 12:50 PM
Mike W's Avatar
Mike W
Sears would be ok. Use a good fluid like Tapmagic.
Old Jan 12, 2004 | 06:39 PM
otto's Avatar
otto
hanson and greenfield also make a nice tap and die set
Old Jan 12, 2004 | 07:14 PM
eehoepp's Avatar
eehoepp
A machine tool supply house will be able to supply good brands. In general, stick with USA or European made cutting tools. You get what you pay for.
Cheers,
Eric
Old Jan 12, 2004 | 08:10 PM
Roger Carter
I agree with otto and eehoepp. I have found Sears/Craftsman taps and dies to be marginal, but adequate, for a home shop. Any tap or die will work better and last longer when used with a good tapping or cutting fluid.
Roger Carter
Old Jan 13, 2004 | 03:00 PM
rebocardo's Avatar
rebocardo
I bought a set from NorthernTools for about $70 and it has been okay. DO use a lot of fluid. I broke my 1/4 tap and had to replace it with one from ... Sears
Fluid, backing the tap out to clean out the metal pieces, slow and straight, are the name of the game to make marginal dies/taps work like good ones.
The better ones cost about $300 and are made from very hard tool steel and are worth every penny if you use them all the time or have to put threads into solid blocks of metal.
