Oh, crap
Old May 31, 2014 | 07:16 PM
tbm3fan's Avatar
tbm3fan
Oh, crap
So the truck is now all painted. The shifter collars are in and the turn signals and horn have been verified to work and work correctly. The truck is ready to take out on the road once again if it would only start. Hold the neutral safety rod in place, turn the key and dead silence. Nothing, nada, nowhere, no how and no matter what I do in the cab
Old May 31, 2014 | 08:51 PM
garbz2's Avatar
garbz2
Pull the wires and jumper the switch. See what happens. The switch may be off just a bit when in park.
Garbz
Old May 31, 2014 | 08:53 PM
crazed87bronco's Avatar
crazed87bronco
Test for voltage at the ignition switch? How about at the starter solenoid? All gauges work that you can see so far?
Old May 31, 2014 | 08:57 PM
Shadowrider123's Avatar
Shadowrider123
Bulb in the alt light socket?
Old May 31, 2014 | 11:03 PM
tbm3fan's Avatar
tbm3fan
After cleaning the switch up with electrical cleaner I put it back in wihtout the wires. Didn't start so I stopped and did some work around the vent on the driver's side. With those two wires dangling besides my head, and noting they both take a male spade, I did make up a small jumper wire to plug in. Bam, started right away. So I guess our trucks won't start even if the switch is simply disconnected. After running it I thought this would be a great kill switch. Remove my little 4" jumper, put the wires back in place, and no one would be able to start the truck unless they were a really great mechanic on the fly.
Old May 31, 2014 | 11:20 PM
rusbukt's Avatar
rusbukt
[and no one would be able to start the truck unless they were a really great mechanic on the fly.[/quote]
Or one of us.
Old Jun 1, 2014 | 09:50 AM
garbz2's Avatar
garbz2
The NSS makes continuity for the starter relay. If you leave the jumper in place it will start the truck in any position. Not a good situation as you go over the bank and in to the creek.
Garbz
Old Jun 1, 2014 | 03:54 PM
jowilker's Avatar
jowilker
Garbz, When you are the trucks only driver and are aware, it aint too bad. Everything I own is automatic, so it goes in park when stopped, is started in park. It really isn't an issue.
It is about like the argument of having loaded guns and kids in the house. You deal with it.
John
Old Jun 1, 2014 | 08:22 PM
tbm3fan's Avatar
tbm3fan
Garbz
That would be a thought although I am the only driver. Maybe one day I'll get the hang of holding the NSS in just the right position to start the truck every time. Yet since I haven't located that sweet spot and the metal lever on the shaft is broken then bypass one must.
Old Jun 2, 2014 | 02:15 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Yet since I haven't located that sweet spot and the metal lever (NSS selector lever) on the shaft is broken then bypass one must.
D0TZ-7B097-B (replaced D0TZ-7B097-A & C5TZ-7B097-A) .. NSS Selector Lever-attaches to shift tube thru hole in steering column shroud / Obsolete
The end of this lever has a knife blade end that pokes into the NSS. It's notorious for snapping off! / Applications: 1965/77 F100/350.
NOS ONLY in San Jose CA has 1 = 800-667-6659.
GREEN SALES CO. in Cincinnati OH has 14 = 800-543-4959.
PERRY FORD in National City CA has 15 = 619-474-6451.
PARTS INTERNATIONAL in Farmers Branch TX has 15 = 888-727-0418.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 2,629 (!) = 800-476-9653.
Old Jun 2, 2014 | 12:41 PM
tbm3fan's Avatar
tbm3fan
Bill, I know about the part being available from a previous post by you on the subject. The problem is that since the metal snapped off from the shaft a new lever would need to be welded(?) onto the shaft from what I see and the shaft isn't coming out in my life.
markeyd
Feb 21, 2016 07:32 PM
beckman
Aug 19, 2013 09:50 PM
alexjp91
15
Jan 22, 2008 07:40 PM
bryant williams
Sep 5, 2006 11:43 AM
nealjpage
Dec 19, 2004 08:47 PM
