Rough idle with Torque App readings
Old May 31, 2014 | 08:54 AM
LiftedBlackHD's Avatar
LiftedBlackHD
I'm experiencing a rough idle with longer than normal crank times. I was hoping these numbers would help diagnose the problem. I have a P2285 dtc which is ICP. I replaced the ICP sensor a few years ago.
I got the torque app and have the following readings:
HPOP/ICP-908
VBATT-14.2
IPR-32
FICM/FMP-44.5-45 at start up 46-47 after a few minutes
MAP-15.12
INJECTION PRESSURE REGULATOR DUTY CYCLE-32.86%
Any ideas?
Old May 31, 2014 | 09:24 AM
npccpartsman's Avatar
npccpartsman
ICP sensor and computer using a default value. Just because you replaced it before doesn't mean it hasn't failed again. Where is your ICP sensor located?
FICM voltage is a touch low but you may need to have a charging system diagnostic run, including separate load test of your batteries.
Old May 31, 2014 | 09:37 AM
LiftedBlackHD
Thats what I was hoping. My icp is on the valve cover and s an easy fix.
It should be noted that the truck runs the same with icp connected or not.
Old May 31, 2014 | 10:19 AM
npccpartsman
You should also check the pigtail for oil contamination and replace it as necessary.
Old Jun 1, 2014 | 09:25 AM
LiftedBlackHD
Pigtail looks OK.
Old Jun 1, 2014 | 09:35 AM
mustang_309's Avatar
mustang_309
Pigtail looks OK.
To add to what Tim said, are you using an OEM oil filter with the OEM oil filter cap? Make sure when you load test the batteries they are completely disconnected from one another. I would also have the FICM taken care of as the FICM voltage should never drop below 45 under any circumstances, the best place to get it tuned up is FICM Repair.com - Your Source for FICM Repair . Here is a video showing the difference between aftermarket and OEM filters,
Old Jun 1, 2014 | 12:26 PM
LiftedBlackHD
Yes I'm using oem filters. Have been since day 1.
Do I need to replace the ICP sensor, yes or no?
Old Jun 1, 2014 | 12:37 PM
04badford's Avatar
04badford
I think it's more of a FICM Issue 44 at start is no good ,you really should check your Alternator on a full load too IE= ac fan on, radio, lights ETC you don't want anything 13.3 or under, this will kill the Batteries , Batteries at KOEO-12.6 low-13.3 high -14.0 anything lower will damage the FICM, Ficm MP koeo- 47 low- 47.5 high- 47.5/49.0
Old Jun 1, 2014 | 01:04 PM
LiftedBlackHD
Batteries and alternator have all been tested and are within spec.
Old Jun 1, 2014 | 01:09 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Check fuel pressure...
Josh
Old Jun 1, 2014 | 01:10 PM
04badford's Avatar
04badford
It May have already done the Damage, 44 is no bueno. What is ICPV at test
imq707s
Aug 23, 2019 09:22 PM
keiseldiesel
37
Mar 10, 2019 08:16 PM
Markus Luukko
Jun 17, 2018 12:58 PM
timmyboy76
Nov 17, 2011 10:12 PM
lakewood
Sep 10, 2011 07:13 PM
